Question about Panasonic Lumix DMC-ZS40 Digital Camera Black
Panasonic Linux DMC-ZS40 zooms in and out opposite way of lever.
I have had my Panasonic for 5 years and recently the zoom has been acting wonky. I will zoom in on something, then if I want to adjust out, it will zoom in more, or I want to zoom in it will zoom out. Trying to get it back to default can take quite a long time. Any ideas? I love this camera.
SOURCE:
lock123
  • 6831 Answers
SOURCE: My panasonic lumix DMC-ZS1 has "Zoom Error". How
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
lock123
  • 6831 Answers
SOURCE: system error (zoom) camera frozen Panasonic Lumix DMC-LZ28
Hello
Regards
Andrea
lock123
  • 6831 Answers
SOURCE: My camera is coming up with a system error (zoom)
Hello
Regards
Andrea
SOURCE: HF10 zoom goes without any explicit request
I own an HF100 and i had the same zoom issue. I purchased a replacement zoom key assembly directly from canon (phone 732-521-7230 cost is about 25 dollars), and installed it myself. This has fixed the issue for me, and i am very glad i didnt have to pay to have it serviced. You can buy the part yourself and install it if you feel confident in your ability to disassemble/reassemble the camera correctly, or shop around for a local camera shop that can swap it out for you.
Posted on Jul 29, 2011
  • 6771 Answers
SOURCE: how do i factory reset my panasonix lumix dmc-fz45
Remove the batteries for 60 seconds, at the same time press power and hold for the juration of the time, this will remove residual voltage and reset the processor ic, "long shot" if no change the zoom part of the lens is malfunctioning, the zoom motor or gears are jammed.
Posted on Apr 05, 2012
Why does my Panasonic DMCFZ28 take pictures when I push the zoom lever?
I suspect the snap key is shot circuited, use contact cleaner spray in the click button often press it to get ride of possible carbon shot circuit between the switch. in some cases the processor will malfunction, and if moisture or water particles gone inside, you must open the cam and clean the motherboard thoroughly with PCB cleaning agent.
Apr 10, 2016 | Panasonic Lumix DMC-FZ28 Digital Camera
My 5 year old panasonic DMC-TZ27 seems to have jammed as it won't switch on!
Try the most basic step first. Please check if the battery is fully charged. If not it is not providing enough juice to the motor that turns the zoom lens. Please charge it fully first and give it a try.
If not, try re-setting the camera. you can find it in the menus.
if not the worst case scenario, the zoom motor is burnt, please take it to the service center for necessary repairs
Feb 22, 2015 | Panasonic Lumix DMC-TZ7 Digital Camera
Zoom lever stopped working on Panasonic lumix DMC-FZ8
Does it say anything about the lever under zoom levers in your owner's manual?
Nov 07, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
Optical zoom and flash not working on Panasonic DMC-FZ7
None of what you describe sounds good. Any chance you can get your money back?
Dec 08, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Zoom
There's a lever on the right hand side, surrounding the shutter release button.
Turn it right to zoom out, left to zoom in.
Hope I helped!
Tom
Jun 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Zoom lever doesn't work
The zoom motor or circuitry controlling the zoom motor has failed. FZ8 parts are still available as far as I know.
Apr 21, 2009 | Panasonic Lumix DMC-FZ8 Digital Camera
Zoom lever sticks
Hi, the only reason the zoom lever sticks is dirt. Either dust or some sort of liquid may have spilled on the camera. If you wipe it off, it does not help as the liquid gets into the zoom lever mechanism.It will have to strippd and cleaned.
Jul 13, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-ZS40 Digital Camera Black Logo
57 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
