Question about Fagor Washing Machines
How to repair fagor LN-35M E WHEN IT'S INDICATING ERROR 10 AND THE MOTOR IT'S SPINNING AT LOW SPEED???
2 Suggested Answers
6ya staff
SOURCE:
robert
  • 2517 Answers
SOURCE: I have an LG washer that get stuck in low spin at 10 minutes left.
If you just do a spin only cycle does it go fully sped?
Posted on May 16, 2018
Testimonial: "No. It will start at 14 min, go slow and finally time out. One in ten times it will run full speed."
May 16, 2018 | LG Washing Machines
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Fagor fe 536 does not spin in max speed
Belt is worn. Replace belt. GOOD LUCK FRIEND.
Jan 12, 2015 | Fagor Washing Machines
F85's "low speed" error
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
sincerely. God bless you
Apr 13, 2012 | Sole Fitness Sole F85 Treadmill
Does not complete the wash cycles. Has code of F6
The "F06" error code is indicating a Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the washer will shut down. If a failure occurs during high speed spin the door will be unlocked after 3 minutes.
Potential Causes:
Loose wire connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). Drive Motor MCU Wire harness I recommend calling a service technician to diagnose and repair your washer.
Jul 15, 2011 | Whirlpool Washing Machines
Error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Jul 14, 2009 | Washing Machines
Fagor, washer dryer , model 2F-3611 flashing code F07 can you tell me what this is please
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Washing Machines
Question: FAGOR FE-1158 ELEGANCE WASH MACHINE
We have a 1 yr old Bosch wash machine w/o problems till now. We have a problem with the centrifuge program-it does not start, although the machine can spin slowly. Is it a motor problem or a problem with the programmer? Thanx for the help in advance!
Oct 16, 2008 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Fagor Washing Machines Experts
Marvin
Marvin
Vernon Taylor
roeb
Are you a Fagor Washing Machine Expert? Answer questions, earn points and help others
