Question about Westinghouse Televison & Video
I need an access code to scan for channels on my Westinghouse flat screen TV.
6ya staff
SOURCE:
Anonymous
SOURCE: how to run channel auto scan
Okay here's how you do it. Sadly they buried this DEEP in the user guide and I stumbled across it -
Press the TV Menu button then with the < or > arrows scroll to the Channel menu. From there you can select the auto scan.
Posted on Jan 10, 2009
Anonymous
  • 35 Answers
SOURCE: need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Posted on Jan 14, 2009
Anonymous
SOURCE: Direct TV remote, need code for Westinghouse Flat Screen 32" itsdon458@yahoo.com
11100 worked for me!
Posted on Apr 07, 2009
Chi Chu
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
jerikol
SOURCE: No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
Posted on Jan 15, 2011
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
(OSD)
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
How to reset my westinghouse flat screen tv
if you are using an antenna for digital channels,it will search for 100 to 125 channels,if searching for the old analog channels,it only searches for 75 channels,but,you will not receive them,they are gone now,if you have a cable box,then you only need channel 3 or 4,
May 18, 2015 | Westinghouse SK-32H540S 32 in. LCD TV
On a 32inch Westinghouse flat screen tv how do I scan the channels without remote
Should be able to press "Menu" button on TV and scroll threw the options, although some tvs you can only scan with the remote ?
Feb 23, 2015 | Westinghouse Televison & Video
Needing the channel access code for a westinghouse tv model DW39F1Y1 serial number 7532V33500473
I need Code the Channel Access, WestingHouse Tv
Modelo: DW39F1Y1
N?mero De Serie: 7531V34300250
Jan 04, 2014 | Televison & Video
I had cable took off and now i want just basic tv the regular channels abc, nbc, cbs and fox but when i try to scan the channels its asking me for a 5 digits access code for the westinghouse
you can go online and get the code. for some reason you have to go to westinghouse website and put in your model serial number abd it will give you a code allowing your tv to pick up local tv channels i dont know the reasong behind this
Dec 18, 2012 | Westinghouse " 40"" Class - LCD - 1080p -...
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Need to program cable remote (att) to tv ( SK-32H640G) do i need a code?
You can do it one of two ways, you can enter a code, (for a Westinghouse TV, normally use the Sony codes) or you can scan for channels. To scan you can normally enter a code sequence which will come in your booklet when you install ATT, you will need to enter the code sequence and scan using channel up until your TV turns off. One the TV is turned off, you will need to press the TV button on your remote and your TV is now programmed. For more information or if you need live help please send me an email to westytech@westinghousedigital.com
Oct 22, 2010 | Televison & Video
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Blank screen no access
try setting up the tv using the default setting
make sure that the tv searches and installs al of the channels
Lou Margo
Allied electronics
Jul 16, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
41 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
