Question about Hoover Washing Machines
Hi- i have a hoover washing machine DYN 9166P-AUS with an E17 error code
SOURCE:
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Posted on May 07, 2008
SOURCE: error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Posted on Jul 28, 2008
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
richroth
  • 9472 Answers
SOURCE: My Hoover VisionHD washing machine
E16 is for an "open circuit" on the heater.
Posted on Jan 03, 2011
  • 6277 Answers
SOURCE: my hoover dyn 8164d washing
Hoover's 'e03' states 'drain timeout'- probably a blocked filter or even jammed drain motor/pump.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 07, 2011
Hi we have a Bosch Exxcel 7 with E17 error code. We've checked filter and pressure. Any ideas??
E17 indicates that water is leaking and getting into the bottom of your machine
Feb 23, 2017 | Bosch Washing Machines
How do your error E17 on a Bosch Maxx 7 varioperfect.
Hi Kerry, The same question was asked on this site back in March 2009 !! and the link below has an answer..... CHEERS..
E17 error code Fixya
Apr 04, 2016 | Bosch Washing Machines
My hoover washing machine model dyn d8p has a code error of ao3/t know what is wrong ..its new and just used then 3 month now but it was not drying well and showing that error code
if it is 3 months old , I suggest that you call the repair shop as it is under warranty
touching it yourself or having any unauthorised person fix it will void the warranty.
Apr 10, 2015 | Hoover Washing Machines
Hoover washing machine manual
HOOVER DYN 10144 DP What does it mean ERROR E13 CODE
Mar 01, 2014 | Hoover Dishwashers
Hoover DYN 9144 DG - 80
washing machine won't start. display screen is flashing constantly, no error codes up. does any one know what the problem is??
Mar 23, 2013 | Hoover Washing Machines
Hi we have literally just brought a Hoover dyn 7164 d and on first check-which the manual asks us to the error code e03 appears and will not drain!!!what do we do??its full of water!how can something...
What a heap of junk of a machine. The one I own died after 13 months taking the electrics in the house out with it. A faulty heating element was the cause. They leak over their electrics with predictable results. A modified element has been fitted. Avoid this and all Hoover products like the plague.
Dec 02, 2012 | Washing Machines
Error Code E13?
HOOVER DYN 10144 DP ERROR CODE E13
Nov 30, 2010 | Hoover Washing Machines
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
