Question about The Computers & Internet
I have a tetra LS three triple light set. I cannot get them to work. When I plug them in the end light flashes briefly and then goes out. Can this be fixed?
    Guru:
  • The Master
  • 531 Answers
There are so many types of Tetra lighting
Does yours look like this?
I have a tetra LS three triple light set. I cannot - 1-lzic241h4ds5idgytq3bspc2-2-0_2.jpg
Posted on Apr 30, 2019
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: Flash won't fire
charging flash:-
POSSIBLE CAUSE:The camera is recharging the flash.
SOLUTION:It takes longer to charge the flash when the battery is low. If this message appears a lot, replace or recharge the battery.
Posted on Dec 28, 2007
Anonymous
  • 16 Answers
SOURCE: We have a Panasonic HDTV
hold the on button then turn up the volume
Posted on Sep 12, 2008
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: tub does not spin
you might have a relay thats shot or the brake solenoid is shot. check both of those, it may fix your problem.
Posted on Sep 12, 2009
ikkenom
  • 10406 Answers
SOURCE: computer won't come on-it gives one short beep. it
One "beep" is good -- multiple beeps mean something is wrong.
Restart your computer, and be ready to press the PAUSE button on your keyboard, to "freeze" that text on the screen, so that you can read it.
Posted on Nov 17, 2009
RE: Friedrich SL28N30B Has Faulty LCDI cord ( will not set -reset ). When plug in blue power light comes on then goes out. Cut cord and installed standard 3 prong male Plug end. Same results- power...
It could be that the faulty cord burned your built in gfi internal switch must like a gfi breaker that gets burn off and never resets . Replacing the cord as you did is a smart move since I would never place an appliance on a gfi receptacle .
May 26, 2014 | Dryers
Replaced three batteries in polder kitchen scale, now it just flashes light. Can't turn on or off and no digital readings
Be sure all 3 batteries are fresh and also be sure they are in correctly .positive+ and negative- , to proper placement in machine. Typically the spring contact points go on the flat -end of battery and the + nipple end of battery goes on the solid or button contact on the machine. Spring end contact points on machine may be an actual spring or a raised metal piece either way they are the end that flexes and holds the battery tight against both contact points. Sometimes the spring must be carefully pulled to make it give more holding pressure. Good luck and I always say Google it!
Oct 18, 2017 | Polder KSC-310-28 Easy-Read Digital...
I can not get the headset to turn on.
If I read everything correctly in the manual I believe the light only stays on when the device is in the pairing mode. If the light flashes every second, the headset is on a call, if the light flashed every three seconds, it is in standby mode.
Standby mode: is when the Jabra BT160 is passively waiting for a call. When you 'end' a call on your mobile phone, the headset goes into standby mode.
Make sure your phone is bluetooth equipped.
You must first successfully pair the headset with your phone. The manual shows you how.....
1. Put the headset in pairing mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to 'discover' the Jabra BT160 Follow your phone's instruction guide. This usually involves going to a 'setup,' 'connect' or 'Bluetooth' menu on your phone and selecting the option to 'discover' or 'add' a Bluetooth device.
3. Your phone will find the Jabra BT160 Your phone then asks if you want to pair with it. Accept by pressing 'Yes' or 'OK' on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Go here for a copy of the owners manual....
http://www.mainresource.com/PDFs/GNBT160User.pdf
Hope this helps.....
Jan 27, 2018 | Jabra BT160 Wireless Headset
No Picture
Hi And Welcome to Fixyah,
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task.
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
May 14, 2010 | Pinnacle Dazzle DVD Recorder
Tub does not spin
Sep 12, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Tv turns on briefly then goes out with red flashing status light
This is exactly intermitent problem, It needs to be trouble shoot at the repair shop if the problems occurs from power supply or high voltage.It needs a lot of test and equuipement to be accurate.And also the specific parts.
r_ic7
Nov 28, 2008 | Mitsubishi Televison & Video
Open Questions:
Computers & Internet Logo
26 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
