Question about Nikon Cameras
I have nikon d5600. The flash is working but it is not opening. Because of that there is burning smell coming from the flash also.In manual mode also it is flashing even though there is no flash needed. Can you help me?
SOURCE:
SOURCE: Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Posted on Mar 21, 2008
SOURCE: How to Fix D50 Nikon flash shutter and light not working
please i want u 2 send me free digital camera
Posted on Apr 25, 2008
MarkDay
  • 111 Answers
SOURCE: Nikon D40 will not flash
The lightning bolt icon in viewfinder blinks when flash is not ready, this can happen if flash doesnt pop up all the way, or if flash strobe tube is bad.
Posted on May 17, 2008
bearydude
  • 62 Answers
SOURCE: LCD DISPLAY FLASHING
THE REASON THE LCD IS FLASHING IS THIS . yOU HAVE LOST THE PROGRAMING ON YOUR MAIN CPU . WHEN THE CHIP IS REPROGRAMED THEN IT WILL WORK .
Posted on Nov 28, 2008
SOURCE: Fault Message on Nikon camera
errr display on sutter speed
Posted on Sep 26, 2009
How do i tun the flash on?
Lacey,
If you don't know how, in the manual are several pictures that show how you can open the flash, by just taking it between thumb and finger and lifting it.
You can select different shooting modes, by pressing the little knob on the back with the camera logo. But when you are in auto mode, the camera will decide when the flash goes on. When you are in other modes, you can put the flash into different modes. Like automatic flash, automatic flash with red eye reduction, off, fill flash or slow sync.
This is all explained in the manual, that is still online. (Nikon has manuals of all the cameras it ever sold, online)
In the English manual, (Nikon USA) it is on page 29.
Success
Jan 19, 2014 | Nikon Coolpix L110 Digital Camera
Nikon pop up flash
This, most likely, will not help you. If it is stuck and you smell something burnt I think your camera has serious problems. I think this is the time to decide REPAIR or REPLACE.
Nov 28, 2017 | Nikon D5100 Digital Camera
Nikon coolpix L110 flash blown. how to replace and how much?
a flash bulb is burned, the burning smell came out. L105 is compatible with? which is found in ebay and is similar to a view.
regards
Jan 26, 2012 | Nikon Coolpix L110 Digital Camera
How to install a Nikon SB-700 AF Speedlight Flash for Nikon Digital SLR Cameras
Basically, you put batteries into the flash, put it into the flash mount on the top of the camera, turn everything on, select a flash mode, and start shooting.
The flash comes with a detailed manual describing its operation. There is a section in the camera manual describing the various flash modes. The SB-700 is fully compatible with the Nikon iCLS system, which includes the D3100.
Since you asked a general question, I can only give you a general answer. If you have any specific questions, please feel free to ask them.
Jan 05, 2012 | Nikon D3100 Digital Camera
D80 SLR lens /flash prob lem
What are your other lenses? If they're not AF lenses, you're not going to get autofocus or metering.
Is your flash not working when popped up? Remember that the flash won't pop up automatically in Manual mode.
Oct 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D40 flash firing when down
Turn off the flash manually (top left button on the side of the camera body above the lens) or use the 'No Flash' Program Dial option - one click back from the green AUTO selector on your dial - the one with the lightning bolt inside a circle.
Jun 30, 2009 | Nikon D40 Digital Camera
Nikon d40
If the camera is in auto mode, the flash opens anytime the camera feels that it cannot take the picture with only ambient light. You can overcome this by closing the flash once the camera opens it or using a manual mode. In manual mode, the flash opens only if you press the flash button on the left side of the flash housing.
May 22, 2009 | Nikon D40x Digital Camera
When shutter depressed "AF" and "SB" LED's flash
My camera's shutter will not depress all the way due to a red flash light coming up all the time in the Flash-Ready indicator lamp (refer to pag 28 in the Nikon manual). It can be full sun outside but it will not work due to the red flash light coming on.
A work around is to select a flash mode of 'cancel'.
There is a button toward the front of your camera called the flash mode button. Click that until you see strike mark on the flash icon of your monitor screen (see page 32 in the Nikon manual).
The camera must have a malfunction of determining the lighting so it always thinks you need to have a flash on the picture. Of course this is not 'fixing' the flash/lighting issue but you can take typical day pictures for now with this work around.
Dec 17, 2008 | Nikon Coolpix 5400 Digital Camera
Nikon d 80 flash will not pop up while in auto mode
The flash up button is located on the left hand side of the camera right near the top.   You should use this button to pop up the flash. Prying it up could/has broken this button.
Also, depending on what setting you are using, the flash doesn't always pop up automatically.   Check to see what mode you are in, on the round dial on the left -- ie  Auto, Portrait, Manual, etc.   I can move sometimes without your knowledge, and this may be the problem.
Apr 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
D40X flash problems
As the manual warns, never operate the camera (or any device, in general) if you notice something like that. Remove the battery, and send your camera for service
One can only guess what was the source of the problem. Did you drop the camera, expose it to high temperatures (e.g. left it inside a car in 40 degrees Celsius) or expose it to torrential rain?
In any case, how long it will take to repair it (or, more likely, replace it) depends on your local Nikon service department.
Dec 08, 2007 | Nikon D40x Digital Camera
Cameras Logo
24 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
