The washer has been very reliable but it decided not to go .i cant find where the acsess for cleaning any filters is located im hoping its not the computer . but it must have a filter somwhere
    Master:
  • 533 Answers
It have filter its front side.... as we remove screws remove cap and it drop.
Posted on May 15, 2019
SOURCE:
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Washer/Dryer
The filter is located behind the removable lower rear panel.
Undo the clip that secures the large black hose to the bottom of tub.
Remove plastic filter and clean, replace , making sure the hose is securely fastened, and test for leaks.
Posted on Jan 04, 2009
barkencoa
  • 3463 Answers
SOURCE: Locating the filter on the Hotpoint WMA54 front load washer
To check and clean the filter, you need to remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction or blockage here and in the pump as well.
Hope this helps to solve your question.
Please leave feedback.
Thanks.
Posted on Dec 12, 2009
Testimonial: "Spot-on advice ticked all the boxes. Problem appears to have been resolved!"
barkencoa
  • 3463 Answers
SOURCE: Clean Filter?
There is a filter at the rear of the washer.
Remove lower rear panel.
Remove large black hose from bottom of drum.
Remove and clean filter in inside hose.
Remove hose onto pump and check for blockage oe obstruction here as well.
Please rate my solution.
Thankyou.
Posted on Jan 27, 2010
  • 949 Answers
SOURCE: Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Posted on Apr 21, 2010
  • 159 Answers
SOURCE: Where is the lint filter located on this washer?HLP21N
Hi.It may be that these machines dont actually have a lint filter,they are making alot of them without lint filters now days.There would be a button trap down at the side or the rear i would imagine for cleaning out debris such as coins,hair pins,Etc.
Posted on May 29, 2010
Testimonial: "Thanks!I will check it out."
I cant figure out where the pump filter is on my ge washer model#wssh300goww
The pump is located bottom right in the front. There should be a panel you can take off . Three screws underneath. If I'm not mistaken there should be an access cover on that bottom panel to get to the clean out filter...good luck hope this was helpful.
Oct 20, 2010 | General Electric WSSH300G Front Load...
Were is the drain system manualy
To access thr pump and filter, remove lower rear cover of washer.
The pump and filter are located at the bottom rear right of washer.
To clean filter, remove large black hose onto drum, and clean filter inside hose.
Hope this helps.
Jan 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Thanks.
Dec 12, 2009 | Hotpoint WMA54 Front Load Washer
Front loader full of water, did the wash and won't drain or spin
It will not spin if it has water in it. you need to remove and clean the filter.
Generally speaking the filter is usually located at the bottom right front of washer.
Some times behind a removeable cover at bottom of washer.
Once you have located it, unscrew the filter anti-clickwise to remove and clean.
Hope this helps.
Dec 07, 2009 | Bosch Washing Machines
As this wd640 is a washer dryer, im sure there must be a filter some where I need to clean etc but dont know how to find it or go about it.... Had a manual but cant find it... thanks Elaine
Hi.
Yes there is a filter.
Remove lower rear panel of washer.
Remove large black hose onto bottom of drum.
Remove hose on to pump, check for obstruction or blockage here, and look inside the pump as well.
This should solve your problem.
Nov 30, 2009 | Hotpoint Aquarius WD640 Front Load...
Im getting f -05error towards the end of all programmes and cant get it to spin or pump out on a hotpoint aquarius wmf50
F05 means that the pressure/\water level switch is jammed on full.
Remove other end of hose onto pump, and check for blockage or obstruction here.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
I cant find the filter on the hotpoint aquarius wd440
Depending on which model you have ,there are 2 possible locations for the filter.
Check to see if there is a removable plastic panel at the botom front of washer, if there is then remove it and if there is a filter there , you will see it, unscrew the cover anti clockwise and clean same.
If no filter there then remove lower rear panel of washer,locate large black hose, and remove clip and hose from bottom of tub,be careful as there will be some water run out.
Remove plastic filter and ball ,clean and replace, and refit hose, making sure it is secured properly.
Test for leaks.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Where is filter
Filter is located in the large black hose attached to bottom of drum, remove hose and clean filter.
Access is by removing lower rear panel of washer.
Plz leave feed back for this solution.Thabnks.
Dec 18, 2008 | Creda W100FW Front Load Washer
Whirlpool front loader washer
NOPE RUBBER WASHER JUST LINE UP THE GROOVES SIMPLE ....
Nov 21, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
