Question about Samsung Washing Machines
Where to get service manual for samsung dw model fg520s, machine is taking and drain 3 times water, after error code IE apear
SOURCE:
  • 1294 Answers
SOURCE: LG Fuzzy Logic won't drain out the water
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 21, 2007
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
SOURCE: samsung fridge model srs535nw service manual
Behind the white plastic section at the back of your freezer (4-6 screws to remove) there is a drain hole at the bottom. This will be frozen and prevent water from defrost from draining away - we have exactly the same problem. defrost the freezer and ensure this drain is no -longer frozen. I used hairdryer and warm water to clear. You may have a secondary problem of defrost cycle going wrong - the most common replaced part is R1098 or something like that a defrost sensor which is easy to replace by removing the top rear plastic section - 3-4 screws to remove and it simply pulls out as it is lightly clipped in. I was worried about breaking it but it came out with a bit of a tug. The defrost heating element is another part which can pack in. I'd replace the other part first and see how it goes.
Posted on Nov 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Macmarkus
  • 2605 Answers
SOURCE: samsung dw model dmr78ahs/xac
Hello, Welcome to FixYa.
The 9E code as it pertains to your Samsung is as follows according to the Samsung service manual...
ERROR TYPE - Low water level detected.
OCCURING CONDITION - Occurs when low water level even after water supply resumes after low level is detected the 1st time.
POSSIBLE/EXPECTED CAUSES - a) Low level sensor defective. b) Low level sensor wire loose/not connected. c) Main PBA fault/defective ( main board )
Steps to resolve-check.
Check for foreign material in the floater of the Low Level Sensor.
- Check the voltage between both ends (pink and brown wires) of the Micro Switch.
When operating normally after water is supplied:
- Check only the Micro Switch.(Remove the connectors before checking.)
Lift the lever: Short
Lower the lever: Open
Results.
- Faulty: Replace the Low Level Sensor, Remove foreign material from the floater
- Normal: Replace the Main PBA assy.
If you don't think this is something within your scope of abilities please call an authorized Samsung service center in your area.
Let me know what you find and I'll be glad to help you in whatever manner I can. I do have a generic service manual for Samsung dishwashers ( essentially all the same as for components and repairs) but you'll need to provide an email address for me to send it via pdf attachment. Good luck.
Regards,
Macmarkus :)
Posted on Apr 19, 2011
-I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
Nov 21, 2011 | Washing Machines
Samsung Dishwasher (DMR57LFS): Error code oE. Fills...fills some more...then drains.
Samsung Dishwasher 0E Error - We had other appliances on that circuit. We believe when those appliances were turned on it created an undervoltage condition in the dishwasher, causing another sensor to send the high level error code 0E. We believe this is the problem because it only started after we added the new hot water dispenser on the same circuit. The problem went away when we leave it off for the whole dishwasher cycle. I'm guessing it could also be caused by brown-outs and other large electrical loads cycling in the same household. That's the theory anyway. The folks who sold us the dishwasher suggested turning off the breaker, to reset the computer. Good idea, but not for our particular case.
Nov 14, 2011 | Samsung DMR57LFS Stainless Steel Builtin...
I have a wf206ans machine and today i had error code that looks like (be) or (he) i cant find the manual for this machine .this code appears on all cycles for the machine washing or spinning only . any...
The manual for the WF206ANS is available here: http://downloadcenter.samsung.com/content/UM/200701/20070131100335625_WF317AA_XAA_02291A.pdf . The table with the code list is on page 22 of the pdf (page E-3). A bE error is a motor speed sensor error. If the code reappears when you restart the cycle, then the washer needs service. For other codes or for service, call 1-800-726-7864 (1-800-SAMSUNG).
I hope this helps.
Mar 27, 2011 | Samsung WF206ANS Front Load Washer
My LG intellowasher 7,5kg WD- 8016c is flashing the letters OE Can you please tell me what this means
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
LED display models LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Washing Machines
Error code ( IE ) on my samsung washing machine model wa13g7q1
Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Morning, LG WD1295FB error OE, plese advise
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. oe_led.jpg oe_lcd.jpg LED display models LCD Display Models Step 1: Check the drain pump filter. Step 3: Confirm that the washer is leveled properly. Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine. An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Oct 26, 2009 | Washing Machines
Samsung J845 front loader washing machine. Error
Hi
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Sep 30, 2009 | Samsung Washing Machines
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
Water won't go out of the dishwasher
Begin at your sink drain that the dishwasher drain hose connects to. Disconnect the hose and check both directions for anything plugging the connection.
Make sure the drain hose has not become "kinked"
(After you have emptied the water from the dishwasher) remove the lower spray arm and the filter in the sump area. Look for obstructions and remove all debris. Rinse the filter thoroughly and reassemble.
If you dishwasher has a timer on the front of the dishwasher that you can manually turn, start a quick cycle with no DW soap and empty.
Allow the water to run in for several seconds and then manually (slowly, gently) turn the timer knob until the DW should begin draining the DW. Listen closely for the sound of the pump motor running.Is water properly draining out of the dishwasher into the drain?
After you have done these things, please post back here and we can take the next steps. OK?
Apr 09, 2009 | Dishwashers
4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Jan 29, 2009 | Washing Machines
Washing Machines Logo
55 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
