What is the model number of my lock? - Washing Machines
How do I lock my Frigidaire stove model 37BAW*5 door
Thank you for your inquiry, longbowshoot!
I see that you would like to lock the door on your Frigidaire range. Normally, the oven door will lock once the self-clean cycle has been started. The model number you have provided 37BAW*5 is not pulling up as a valid model number. Are you attempting to lock your control panel? If so I need your model number to further review steps on locking your door. You can locate the serial tag (which lists your model number) behind the lower drawer of your range. I look forward to assisting you. -Matt
Dec 07, 2014 | Frigidaire Kitchen Ranges
Key symbol showing unable to use machine
Child Lock has been activated. Since differerent model require differerent key press sequences all I can tell you without your model number is to find your owners manual and look up the finctions of the child lock so you can de-activate it.
If you can not find an owners manual I will need a "make and model" "type or series" if you can not get access to the model number because the door is locked. Usually a model number is located on the upper kick / toe panel at the bottom of the unit under the door. I need some thing to begin any manual searches so that we can get this resolved.
Thanks for choosing FixYa,
Kelly
Jul 30, 2011 | Washing Machines
Is there a light that should come on when I press the num lock button? I can't tell if the number lock is on???
It depends on the keyboard model. Some have a number lock indicator light. There is no standard for location, either. The most common place for Caps lock, number lock, etc. on a desktop keyboard is behind the number key pad. However, some keyboards put the caps lock indicator right in the Caps lock key. There's probably at least one model that does the same for number lock. Many laptop models have no indicator, or a tiny one set somewhere in back bezel.
Some operating systems and applications have an option for displaying the status in the menu bar. If you can't find the number lock status indicator, you may have to resort to observing the behavior of the system when you hit a key on the number pad. If number lock is off, the even numbers (not including 0) will be arrow keys and the odd numbers will be page navigation keys.
Jan 20, 2011 | Computers & Internet
It will not spin, it does everything else ok
This problem is commonly caused by the failure of the door lock system. The machine has a safety feature that prevents the high-speed spin cycle to commence unless the machine control detects the door is locked through the door lock switch.
Check if the door lock light is lit. If not, then the door lock and/or the machine control has indeed failed depending on the model number of the machine. If yes, then the motor speed control is the problem. Indicate the exact model of the machine for more specific troubleshooting and repair advice. The model number is necessary for exact replacement part numbers should a part replacement is required.
Dec 09, 2010 | Maytag Washing Machines
I lost the keys to a Sentry safe HD2100 can you help ?
The lock needs to be 'picked' or alternatively drilled the latter would destroy the lock. Any locksmith should be able to open and rekey the lock without damaging the lock or safe.
GET QOUTES!
Sep 23, 2010 | Sentry Fireproof Safe
I need to open a sentry safe.The key is locked inside
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Sep 01, 2010 | Sentry Safe OS0810: Safe Fire-Safe ®...
Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool: lost key: Sentry 1100 strong box....
In Summary:
May 18, 2010 | Safe International Digital Electronic Safe...
I have a E71s phone with some model numbers on it 850/900/1800/1900 and it says to input phone lock code
The numbers you see are not model number. Try entering the lock code in which you used.
Oct 19, 2009 | Cell Phones
Lost key sentry model 1170, where can I get a duplicate key?.
A locksmith can fit keys the the sentry safe 1170. Sentry safe lost key replacement is availble. You do need to know the key # that is on the face of the lock to cut a 1170 key by code.
Jun 08, 2009 | Sentry Fireproof Safe
Key board probs
Would these be keys that can also be used to enter numbers? do they have numbers on them as well as letters ?
If so I'm thinking that there is some sort of Num. Lock activated (perhaps via an FN key ?)
Can you tell us more about the laptop, make and model ?
Oct 18, 2007 | Computers & Internet
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
