What is needed to repair Laser 73 oil heater?
Fan makes noise & does not spin fast
SOURCE:
  • 193 Answers
SOURCE: The heater (fan) makes a loud noise.
The most obvious problem could be that something has fallen down into what is called the squirel cage of the fan.
Every once in a while a mouse will decide to build a nest there.
Posted on Nov 26, 2008
SOURCE: I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Posted on Aug 27, 2009
  • 7353 Answers
SOURCE: 2006 sorento w/43,000 miles-the fan for the air
possible air door problem. those have a 100k warrany right? take it to your favorite dealer.
Posted on Sep 17, 2009
  • 17 Answers
SOURCE: 2003 Forester Heater AC Fan Blower makes loud noises
it is electric, so oil wont help, call your local parts store they should have access to one in a day or two
Posted on Dec 13, 2009
ftw1952
  • 10319 Answers
SOURCE: How do I repair a noisy heater fan?
replace the motor for the noise is fron the internal bearing that is worn
Posted on Feb 06, 2010
Laser 73 will not have ignition , it has fuel it start with a green light and in about 3 to 4 mintues the fan start to run then i get a error 2
ee 2 is the code for no ignition. This can be caused by a dirty fuel filter or dirty fuel strainer. The flame rod may need to be cleaned. The igniter may be burned out. Could also be a circuit board problem. If the fuel pump makes a loud ticking or thumping noise then it is a fuel flow problem and I would check the filter and strainer first. When checking the flame rod be sure to unplug the heater first.
Dec 12, 2010 | Rinnai Toyostove Direct Vent Heater:...
Error reading ee8
EE 8 is for a blower motor problem. It could be the sensor that checks the blower speed or it could be the blower not running. If the blower is running, the sensor is bad and you will need a new blower. If it isn't running then you may be able to fix it. Sometimes on the Laser 73, soot and carbon will build up on the exhaust fan blades. Remove the fresh air hose, that is the rubber on the back, and look for the fan blades. If you can see them turn the heater on and see if they are turning. If not turn the heater off and try to turn them with your finger. If you hear a noise like something rubbing when you turn it or feel some resistance, keep turning it until the noise stops or it frees up. Now turn it on again and see if the fan runs. If you don't have anywhere local to get parts I can get them for you. You can contact me at nitensheaterservice@earthlink.net I may also have a used blower that will work.
Nov 14, 2010 | Rinnai Toyostove Direct Vent Heater:...
Laser 73 fire will start but the circulation fan will not start. will eventually overheat and then shut down with EE 2 error. Whats up?
Because you have the EE2 error I would say there is nothing wrong with the circ fan. Your are either having a problem with fuel flow or the igniter. Feel around the two red wires when you try to start the heater. If they get hot you have a fuel problem. If you also hear a thumbing noise you have a fuel problem.
Tom
Sep 27, 2010 | Rinnai Toyostove Direct Vent Heater:...
My toyo 73 has started making a loud vibrating noise during startup but gets quiet after running a little while...the fan is not on during start up....
The fan blowing air to the room might not be on but the flue fan would be. I reckon this is where the noise might be from. Fan impellors get coated with dust and this throws the balance out (similar to a car wheel if you loose one of the balance weights). Highly recommend getting it serviced by a good technician. Always good practice every year or so and might fix the problem.
Sep 20, 2010 | Rinnai Toyostove Direct Vent Heater:...
Need to reset temperature control on my toyostove laser 73
I'm not sure if I'm answering the question right, but the reset light should reset when the heater cools down. If not you may have a problem a circuit board or a bad temperature sensor or loose wire. You should find out why the heater overheated. It could be a dirty fan or fan cage or something else blocking the air flow.
Jun 30, 2010 | Rinnai Toyostove Direct Vent Heater:...
The bearings are making noise in the blower fan motor.
You will have to replace the motor,or have a company replace the bearings if you know of a motor rebuild place.
Nov 06, 2009 | Rinnai Toyostove Direct Vent Heater:...
A whirly noise when heater first starts, continues throughout cyc
The noise went away on its own.  I had kept the heater off for a few days before this started.  I checked with the local distributor and they thought that I had a problem with the bearings in the small fan motor that pushes air for the heater to burn as well as move the exhaust out.  The problem presents no real danger but it will fail eventually.
Mar 25, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo 73 makes constant noise when running
Could be the blower or fan motor if you haven't had it cleaned in a while.
Nov 24, 2008 | Rinnai Toyostove Direct Vent Heater:...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
