May tag 3000 starts to fill then stops and door unlocks. What could cause this to happen"
After I lock my car, go shopping and unlock the door, my alarm goes off...how can I stop this from happening?
Try unlocking the door manually with the keys. If problem still happens. Your door or hood switch may be defective. They will send a false signal to the alarm that indicates one is open.
Mar 09, 2015 | 2007 Chrysler PT Cruiser Touring Hatchback
Zanussi Washer Dryer wont wash!
Sounds like the switch that tells the controller that the door is closed and locked is actually bad or the plastic molded part holding the switch is broken. Inspect the interface for cracks.
Nov 22, 2014 | Zanussi Washing Machines
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
1999 chrysler town /country van .horn blowing lights blinking wont stay running or wont start
This is your security system. Your van thought it was being stolen. Next time do not leave your keys in the van and lock the doors.
Jan 03, 2018 | 1999 Chrysler Town & Country
Slow pc problem
In all likely hood you have too many programs running at start-up even though you may have not opened them. This ties up the Processor and fills up the Ram. So, try downloading a free program that is a utility to clean up your PC. There are several good ones available at Download.com. I'm listing them in alphabetical order. Advanced SystemCare Free at http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html?tag=rb_content;main or Glary Utilities at http://download.cnet.com/Glary-Utilities/3000-2094_4-10508531.html?tag=rb_content;main Then, be sure you don't have a bug by installing a goo Malware like Malwarebytes Anti-Malware at http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=rb_content;main Afterward, you can go in and select which programs are important to you and stop them from self starting. Please note that it never stops, so run weekly for best results. If it is more serious than this, take the unit to a good repair shop that will guarantee results.
Dec 29, 2011 | Computers & Internet
I have a hard time starting my 04 Santa Fe after i fill up
The most common cause of this is thermal shock (gasoline is very cold out of the ground) to the electric fuel pump inside the fuel tank, when the pumps get worn the decrease in temperature from the gasoline causes the pump to stick. This is a question I see fairly often, so I did research to see what the common cause is. Next time this happens have the fuel pressure checked.
Mar 30, 2017 | 2004 Hyundai Santa Fe
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Kenmore elite HE 3t - error code F dU and door is locked
Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
My DMM for HDD060/00 will not start
Are you copying songs from MP3 or Audio CD ?
If you are copying from Audio CD, it wont work.
Extract your audio CD to MP3/WMA using any of the below softwares
1)  http://www.download.com/Free-CD-Ripper/3000-2140_4-10212165.html?tag=lst-1&cdlPid=10396883
2) http://www.download.com/Audiograbber/3000-2140_4-10016038.html?tag=lst-2&cdlPid=10262582
3)  http://www.download.com/CD-Copy/3000-2646_4-10015689.html?tag=lst-3&cdlPid=914605
May 26, 2008 | Computers & Internet
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
