Question about Toshiba Televison & Video
Toshiba 50L711U18 black screen.
We have a Toshiba 50L711U18 tv that is 1.5 years old and the screen goes black as soon as any input device is attached. Without anything attached, the TV boots up and is fine and we can scroll through the Menu. Leaving TV off, unplugged, 30 second power reset did not fix the issue. Looking for help to see if this is something I can repair myself by ordering in a part or if it has to go in for service or be set out by the curb. Hopefully it is something i can do since i cannot afford to replace it at this time. thank you! Also, same issue regardless of which HDMI port is used. Setting the backlight to "0" does allow the TV to actually work for a little while, but eventually the screen goes dark again.
  • Toshiba Master
  • 418 Answers
Hi Daren, it's a very strange fault, the one you mention
I sent you a link that talks about a similar failure on a Toshiba TV
I hope it will help you and you can solve the problem
But I suggest you look for a specialized technical service
Greetings Franco Dosil
Hola Daren, es una falla muy extra?a, la que comentas
Te envio un link que habla de una falla parecida en un televisor Toshiba
Espero te sirva y puedas resolver el problema
Sino te sugiero busques un servico tecnico especializado
Saludos Franco Dosil
Posted on May 15, 2019
Testimonial: "Thank you very much for the help. I have already done this test and it did work but only for a few minutes and then the screen shut off again. So it does look like we will need to consider getting it serviced. Thank you again Franco for the speedy response."
  • Franco Dosil
    Franco Dosil May 16, 2019
    Hello Daren, thank you very much for your comments, I regret that you have not been able to solve, for the moment the problem of your Toshiba
    I hope you find a Good Technical Service and resolve the issue, I wish you the best possible management
    Hola Daren, muchas gracias por tus comentarios, lamento que no hayas podido solucionar, por el momento el problema de tu Toshiba
    Espero que encuentres un Buen Servicio T?cnico y resuelva el tema, te deseo la mejor gesti?n posible
SOURCE:
  • 5 Answers
SOURCE: Toshiba 50H81 Re Blinking Light...wont work
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the net and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
Open back cover, 9 screws and wirings (pls mark), removed(soldered) a electronic board infront of convergence ic. removed IC (stk392-110) (screwed and soldered).
Replaced everything and voila...! it is now working again..
no more shutsdown and red blinking light. Saves me $400 for a repariman. of course just be careful with static and stuff.
I don't know how to solder, so I ask friend to do it for me. But I did the rest. Just to give you an idea that it can be done even if you don't know much about electronics. This in no way a recommendation but just stating my experience. Follow at own risk.
Posted on Mar 17, 2008
SOURCE: toshiba 32a33 32"tv
My dad and I fixed the TV/Video problem over the weekend using one of the solutions suggested. Make sure you stay away from the red wire running from the back of the tube to the circuit board.
1. Take the cover off the back of the TV.
2. On the bottom of the TV is a circuit board that is mounted on top of a plastic tray. Remove the cables running from the speakers by squeezing the tab on the white plug and pulling them up and off the board.
3. Looking at the back of the TV, pull the board+tray out (barely secured in there) and flip it 180 degrees so you're looking at the front of the board.
4. Desolder and remove the TV/Video push button. It's labeled on the PCB, and should be the second button in from the left.
5. Place the tray back in the TV and make sure the other buttons still remaining on the baord are aligned with the buttons on the front of the TV.
6. Put the cover back and you're done.
TV works as good as new again. Of course I can't use the TV/Video button on the TV itself, but the remote handles that fine. 20 minutes max, and no repairman needed.
Posted on Jul 07, 2008
SOURCE: Audiovox LCD FPE3206 problems
Hi, All.
I ordered a new power supply module on ebay. Cost about 106.00 delivered. Came in a few days. I replaced the unit, bunch of screws, all wires were cable plugins, no problems at all.
After reassembly, it worked. What can I say? Sometimes ya just get lucky.
tom
Posted on Oct 21, 2008
asnowman
  • 788 Answers
SOURCE: blue screen after distored colors on a Mitsubishi WS - 55807
Your symptom sounds like at least one damaged convergence IC.
On Mitsubishi's you can sometimes rework the solder connections on each of these IC’s, although, if the convergence does not fix itself from time to time, you most likely do not have a bad solder connection. You will have a faulty IC. I recommend to replace them both at the same time because the chips legs can fall off due to the heat of the IC.
Please be sure to remove all of the white heat sink compound on the heat sink and apply a even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I believe that your set has two. They are secured to a very large aluminum heat sink. I think that the IC numbers will be IC8001, 80002.
The IC’s are large and black, you cannot miss them. They will usually have an STKXXX-XXX number on them.
This repair from a good technician will normally run from $250.00 - $300.00.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact Hitachi part, or Sanyo, even though the numbers on the front are the same, and they look exactly like the $10,00 ones, they are better and more reliable.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 22, 2009
  • 8457 Answers
SOURCE: My LG tv has a mind o its own. First off, the tv
The tv PCB board manual contol buttons board is shorted,that why u have ramdoom screen menu pop up.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tv manual PCB control board for the replacement.
Posted on Jan 15, 2011
My 55inch LG 3D smart tv is not working properly. When you turn the tv on the LG home screen comes on for a few seconds, and then the screen goes black. What is causing this
it's set to the wrong input device ? the one you currently have it pointed to has no input
also it's possible that cable plugged into current input channel has gone bad or become disconnected from it's source
Hdmi cables are unfortunately famous for this as they have no Lock device to keep them inserted into ports
most TV's nowdays shut off if not provided an input for a few minutes
Jun 01, 2015 | LG 55LM6700
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
My 42 inch toshiba plasma tv. about 4.5 years
Ur backlight video inverter board is dead or defective,need it replaced.Tries these websites Shopjimmy.com or Partstore.com or Ebay.com.
Sep 01, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Plasma tv screen goes black once you turn it on. Only sound
I have a panasonic TH-42PX60U plasma TV. When I watch TV programing I have no problems, or with the DVD input. But if I switch to another input, be it video game (PS2) or vcr the screen sometimes goes black and the red power lcd light next to the power switch flashes. Holding the power button in for a few seconds will shut down the tv. Then I can turn it back on and it may operate normally again for a undetermined period of time, before the screen goes black again. This never happened when new. The tv is about 1 year old. Any ideas on this problem? Thanks Ernie
Aug 13, 2008 | Televison & Video
Toshiba 32AF41 Power up Problem and Green Screen
My first inclination would be to check the picture tube, especially if the set is over 7 years old. If it is not that, then anything from bad solder connections to capacitors or a defective IC could be the cause. If it's over 10 years old, replace it. No use flogging a dead horse.
Jan 13, 2007 | Toshiba 32AF41 32" TV
Televison & Video Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
