How do I stop leaks for our Claber Aquauno video -2 ?
We put in new washers. One might be too thick. Lowes had hundreds but not the exact size needed. Where can I get washers that fit the top big ring that fits over the smaller insert that has the filter/washer I it?
SOURCE:
  • 156 Answers
SOURCE: Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Posted on Mar 06, 2008
larryyb
  • 291 Answers
SOURCE: Drip tray for LG washer
all washers will leak for one reason or other / eather over load or shaking or something so be safe and get a pan that will fit and save your floor and ceiling
Posted on Dec 13, 2008
  • 50 Answers
SOURCE: Dakota power steering leak
That's the power steering pressure switch and it is very easy to replace. I don't know how much the part is, but it cant be very much. It's a very simple switch. I'd just replace it.
Posted on Apr 14, 2009
gary1121
  • 332 Answers
SOURCE: Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
Posted on May 30, 2009
apart4u
  • 213 Answers
SOURCE: how to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
Leaking inside at the beginning i cannot see.
Have the same problem - no idea how to fix it as of yet...
Mar 16, 2013 | Claber 8990 Rotoroll Automatic Hose Reel...
Making a shimm for a guitar
depending on what you are shimming here are a few options. 1. home depot or lowes actually sell different sized shems according to there thickness just ask someone in lumber and they should be able to direct you to them. 2. your guitar picks come in all different thickness's so you can cut and trim them to the size you need to shim whatever your working on.
Jan 09, 2013 | Ibanez Music
My winner 11, has developed a bad leak and has lost pressure, i assume I need a set of O rings, where can i purchase spare parts, i live in Adelaide
If there is no Karcher agent near you, most hardware shops and bearing outlets keep a range of o rings in stock. Take samples ot the part with you to get the correct size and thickness of o ring for your needs. Remember to put a bit of lubricant on the o ring when installing it.
Apr 07, 2011 | Karcher K2.26 Electric Power Washer
Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
Nov 24, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
How to wire home communications
You are correct from your description. The larger cable is more than likely audio connections for whole house audio and to hide the components.
The best thing i can think of is to go to home depot or lowes and purchase a "wire tracer" and connect to the wires and " tone" the wires to see where they start and finish.
The main idea from what you explain is audio/video connections.
The one above the FP is probably video for the tv and MAYBE power as well.
Mar 10, 2010 | Home Security
When i turn on console 3 red flashing lights appear, 1 is not flashing, cannot do anything on it, ie... play games listen to music
I will help you. Go to lowes or home depot and buy M5 5x10mm screws, M5 washers stainless steal 1mm thick. These ar the perfect size screws for the job. You will be doing the X-clamp fix. Contact me at console.mods@yahoo.com for further info.
Jul 06, 2009 | Microsoft Xbox 360 Console
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
May 30, 2009 | Karcher K2.26 Electric Power Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
