Question about Kenmore Washing Machines
I have a kenmore 80 series heavy duty washer which previously had a Lid switch bypass. I would like to undo this bypass and put in the lid switch. The bypass has a grey and a white cable, both held together with electrical tape. There are two ground wires. One has been shortened, the other has the is screw to the washer cabinet. Any help or advise would be greatly appreciated.
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: kenmore ultra fabric care I washer; 80 series- lid switch needs replaced
This is a very easy problem that you can repair yourself. The following link explains in detail how to replace a lid switch such as yours:
http://www.fixya.com/support/r385198-replacing_lid_switch
A replacement switch can be purchased on line at any of the following sources:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
All three sites offer great service and have competitive pricing. So, shop all three for the best price. Just use your COMPLETE model number (usually located under the washer lid along the tub rim) to begin your search criteria. If you do not wish to order on line, use the part number provided by the Sears website and go to your nearest appliance parts retailer. Yes, this a part that they should carry in their inventory.
If you have questions, or need further assistance, please let me know. I hope this helps you.
Posted on Jan 16, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
The following link explains how to replace one:
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
Maytag317
  • 1136 Answers
SOURCE: kenmore washer lid switch bypass failure.
HI. Check and see if you might have tripped the breaker. If there is a ground fault outlet close by. check that as well.
It sounds like you bypassed it properly. Try and reconnect the wires with the wire nut. Sometimes it doesn't connect properly.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
mgprice
  • 744 Answers
SOURCE: kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Oct 14, 2009
  • 1937 Answers
SOURCE: HOW DO I BYPASS KENMORE SERIES 80 LID SWITCH
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jun 08, 2010
My Kenmore 26442502 top load washer will not kick into the spin cycle after it agitates. Just kinda humms. As I open the lid while it should be spinnning, everything stops, like it should. Once I close the...
Hello Dbriner,
It would appear that the lid switch is defective and is in need of replacement. I included a video showing basically how to replace it (It is a series 80 machine but that is minor).The steps are the same.
Your part can be found here for $29.65 +Shipping
Good Luck!
Rich Lilja Kenmore Washing Machine Lid Switch Assembly WP8318084
May 20, 2017 | Kenmore 24032\24036 Top Load Washer
My kenmore ultra fabric care heavy duty 80 series model 110 will not drain. The problem occured after a heavy load knocked the lid switch off during the spin cycle. How do i fix this/replace the lid...
Nov 05, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washers, heavy duty 80 series, no spin
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
My cloths washer wont drain or spin. Its a Kenmore Heavy Duty 60 series.
May be the lid switch. Canyou hear the switch click when you close the lid? It will be just before the lid is all the way down.
Sep 08, 2009 | Tecnik TKL9260 Front Load Washer
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
Washing Machines Logo
Sal De
fordexpert
Whirlpool
Whirlpool
