Question about Miele Professional PT7136 Little Giant Stainless Steel Laundry Dryer Stackable, 15Lb 6.5Kg 34Gal 4.6CF Honeycomb Drum, Hot/Cool Air, Moisture Control
Hello! We have an tumble dryer Type: pt7136. Tumble dryer not stopping when clothes are dry. Timer on display is counting down, but timer value increase when nearly finish why?
    Top Expert:
  • Miele Master
  • 29,179 Answers
It has sensed that the washing is not dry, so it adds time.
Posted on May 16, 2019
SOURCE:
blueextc3221
  • 15935 Answers
SOURCE: KitchenAid Dryer Timer stopped working - won't stop drying
Timers cannot be repaired. The mechanism is a spring - once it weakens, or fails - a new timer is required.
CLICK HERE for your part.
It is $83.72 USD.
Here is a Buy-it-Now eBay auction for $34.99USD & Free shipping!!
CLICK HERE
Your part number for the timer is 3976570a
A used part would have to come from an appliance store that salvaged from an abandoned washer.... and it may fail shortly anyway.
The new timer will have a warranty, and give you 10 more years of service.
Well worth it.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 06, 2009
  • 347 Answers
SOURCE: I have a Kenmore Dryer model 68731 where it does
heat sensor problem
Posted on Oct 23, 2009
  • 494 Answers
SOURCE: dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
Posted on May 15, 2010
  • 523 Answers
SOURCE: My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Posted on Jun 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet electric dryer timer stopped
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Timer counts down too quickly
Possible there is fault in the timer unit . check for loose connections or loose joints to the unit, if not this needs a replacement.
Jan 12, 2013 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Timer stops at 6 minutes but continues to tumble.
You will need to replace the auto dry sensor on your dryer.
Mar 11, 2012 | LG DLE2516 Electric Dryer
Dryer will not stop running
May 15, 2010 | Frigidaire Electric Dryer
Intermittently Drying Problems, Electrical?
It could possibly be electrical, check for 240V at the supply side. The only other possibility could be plugged dryer venting, although it would be unusual for it to cause only intermittent problems. The reason the timer would stop turning (mechanical timer) or counting down (digital display), is because on any Auto-dry, (ones that use the moisture sensor) the dryness of the clothing dictates when the timer should count down or advance. Check for good airflow from the outside exhaust point, if that's ok, I would be possibly looking at the outlet for possible loose contact, look at the dryer cord prongs and see if there are dark marks on them, as this may point to a sloppy outlet causing arcing.
Nov 28, 2009 | Frigidaire Electric Dryer
Hi. Our dryer will start normally and then the
HI. This will occur when the there are issues that concern the integrity of the timer motor. This mechanism is responsible for the rotation of the timer module.It is damaged at this time, and it must be replaced asap.
A damaged timer motor will affect the nature of the drying cycle. It is the main initiator of all functions during the selected cycle.
Oct 29, 2009 | Dryers
Tumble dryer will not dry
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 19, 2009 | Dryers
It is $83.72 USD.
CLICK HERE
Well worth it.
May 05, 2009 | KitchenAid KEYS850LQ Electric Dryer
Miele Professional PT7136 Little Giant Stainless Steel Laundry Dryer Stackable, 15Lb 6.5Kg 34Gal 4.6CF Honeycomb Drum, Hot/Cool Air, Moisture Control Logo
32 people viewed this question
Top Miele Dryers Experts
Mike
Dw Wooten
Dw Wooten
ray gallant
ray gallant
Are you a Miele Dryer Expert? Answer questions, earn points and help others
