Question about The Audio Players & Recorders
How do I play the 3 disc CD player? My model is 646-2T1064A Compact disc digital Audio.
  • The Master
  • 26,825 Answers
Something is wrong with that model number as Google can't find it. The search query would be
make model manual
https://www.google.com/search?q=646-2T1064A+Compact+disc+digital+Audio.&sourceid=ie7&rls=com.microsoft:en-US:IE-ContextMenu&ie=&oe=
Posted on May 16, 2019
SOURCE:
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
  • 85 Answers
SOURCE: Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Posted on Jan 08, 2009
  • 46 Answers
SOURCE: Disc error when reading dvd
If cleaning of the lens did not help then it is possible that the laser beam torch needs a replacement. Different formats need different strengths of the beam and the torch would need to be replaced.
Posted on Jan 15, 2009
SOURCE: My JVC cd player, plus Mini disc, and radio. CD will not play
Thank you for your email. The problem must have been dust. I kept putting the cleaning disc in for quite a number of times. Thankfully the problem was simple and it is playing super.
Kind regards to all.
Tonytopaz
Posted on Oct 13, 2009
  • 21 Answers
SOURCE: Emerson 3 Compact Disc Player
Hi
If the machine cant read the table of contents of a disc this would suggest either the lens of the optical pick up is dirty or the optical pick up has failed completely or something directly relating to the optical pick up i.e the spindle or stepper motor, if you can easily acess the optical lens you maybe able to clean it using a cotton bud and re-test, just try this with a dry contton bud to begin with if this gives an improvement you may wish to use a cotton bud with a alchol cleaner like I.P.A,
make light circular movements over the lens. If this makes no difference the machine requires repairing, so consult a local service engineer.
regards
TechSupp12
Posted on Dec 11, 2010
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Why doesn't CD play?
The CD player has failed and will have to be replaced
Feb 02, 2016 | 2002 Isuzu Rodeo
What dsks does the CD player play. Does it play MP3 disks?
mp3 is actually a file format that made larger audio files take up less data space. If you have mp3 audio files on a compact disc(CD) it may play it if the player is designed to recognize the format. This was a much bigger issue years ago. Only way to tell is check the manufacturers specifications or simply try it. Good luck.
Apr 25, 2014 | Thomson RK300CDU CD/MP3/Radio/Cassette...
I need a manuel for my RSQ-MV-333, where can I get one?
Retrevo has the manual for the RSQ MV-333 here: http://www.retrevo.com/support/RSQ-MV333-DVD-Players-manual/id/8203ag317/t/2/ . You will need to enter a code to download the file; then use Adobe Reader or a similar program to read the manual.
The unit can play compact discs with digital video, compact discs with digital video and playback control, CD-G (compact disc - Graphic) and audio CDs (finalized CD-A discs, not MP3s or open CDs made on your computer).
I hope this helps.
Dec 20, 2012 | Cars & Trucks
Marantz cdr420 recorded media stored on harddrive.played back all fine unplugged now it says no valid files when i try to burn the disc but the drive reads full.
If you are attempting to burn mp3 files as an audio CD, then that's the problem. You cannot burn audio CDs from MP3 files. You have to burn MP3 files as a data CD and not as an audio CD. See excerpt taken from page 33 in the CDR420 user guide. "Prepares CDs that can be played on standard CD players. Compact Disc Digital Audio (CDDA) uses uncompressed PCM, .wav files. The CDR420 does not convert MP3 files to PCM so MP3 files are ignored if you choose AUDIO as the CD TYPE"
May 04, 2010 | Marantz CDR420 CD Recorder
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
Denon CDR-W1500 not recording
I had the exact problem and could not get any of the CR-Rs that I had to work. I looked up the code in the user's manual where it said the error means it's not a recordable audio CD and to refer to page 6. I looked at the front of the manual and saw that it mentions that the CD-Rs must be audio CD-R discs. I did some research online and found that there are in fact differences between CD-Rs that are just marked that and those marked as Audio or Music CD-Rs. I bought a set of CD-Rs that clearly had marked "Compact Disc Digital Audio Recordable" on the package. When I inserted this disc, I had no problems getting the recording to work. So, make sure the discs you use are clearly marked "Audio" or "Music". A computer burner won't know the difference, but your Denon recorder will.
Jan 27, 2009 | Denon CDR-W1500 2-Disc CD Recorder
Phillips pet 706/05 dvd player wont dvd-r-rw
  • Disc not loaded. Load a disc into the player, close the door and press PLAY.
  • The disc used may be defective. The disc used may be defective, try another disc.
  • The disc is placed improperly in the tray. Make sure the disc is properly placed and centered in the tray and if the disc has a label on one side, make sure the label is facing up.
  • The disc is dirty. Use a soft cloth to clean the disc by wiping in a straight line from the center of the disc to the outside edge.
  • Use of DualDisc or Flip Disc which does not meet the Compact Disc Digital Audio Standard. Some music labels have recently introduced the DualDisc for pre-recorded audio and video content. The DualDisc bonds DVD content on one side 'back-to-back' with digital audio content on the other side. However, the digital audio side does not meet the technical specifications specified in the Compact Disc Digital Audio Standard. For this Reason, DualDisc is not permitted to carry the CD logo. Philips DVD and CD players and disc drives fully comply with the CD specifications and therefore may not recognize the DualDisc. Attempting to use DualDisc may lead to playback problems or jamming in the slot loader or drive.
    The DVD video content on the DVD side of the DualDisc should play on Philips DVD players and DVD drives. However, Philips DVD players and drives do not support DVD Audio, and will not play any DVD Audio content present on the DVD side of a DualDisc. Philips will further investigate DualDisc and update this notice accordingly.
Jul 18, 2008 | Philips Televison & Video
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
19 people viewed this question
Top The Audio Players & Recorders Experts
meowwl
Level 1 Expert
D. E. Hev
Martin van der...
Martin van der...
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
