Question about Brother InnovIs 4000D Computerized Sewing Machine
I just bought a gently used Innovis 4000d which came with a flash drive. 1st my computer will not recognize it when plugged in, 2nd when its plugged into machine it says to "Load USB media". Help
  • Brother Master
  • 6,032 Answers
Unfortunately, you are missing some software. You need the original PE-Design software CD. Then you can install the Upgrade software from https://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=hf_inov4000deus for your OS version. Until this software is installed, the computer will not find the driver for the sewing machine. The driver is not available from Windows Update.
The USB drive may have new firmware that wasn't properly installed. To load firmware, insert the USB drive when the sewing machine is off. Then press and hold the Automatic Threading button while you turn on the sewing machine. Follow the directions on the screen (see the manual on page 224: https://download.brother.com/welcome/doch000013/nv4000ug04en.pdf ) . Turn off the sewing machine and then remove the USB drive before sewing.
I hope this helps.
Posted on May 16, 2019
SOURCE:
SewTechWayne
  • 186 Answers
SOURCE: error on Brother Innovis 4000d sewing machine
You probably need to take it in for service. Thread guide pulse motor (TG-PM) is jammed with thread. There is a new shield that that can install to keep this from happening again.
You can gently try to move it with the machine on and see if that works, it is the little shuttle that goes up and down on the front of the machine, it is probably stuck where you can see it.
good luck!
Posted on Jan 31, 2009
  • 34 Answers
SOURCE: can I transfer a pattern from brother 4000d machine to usb
Welcome to Fix Ya!
Are you trying to transfer a built-in pattern from your machine to a USB flash drive? I'm not sure if built-in designs can be transferred in their original form. You might try editing the design a bit, save it to a memory space, then save it to the memory stick. If you have a manual, it should describe how to move designs from your embroidery machine to your computer, and vice versa.
If you are other readers have time to rate my answer, you'll help me become a better expert. If you can give me more specific information about what happens when you try to upload a design from your machine, and whether you have a manual feel free to leave a comment and I'll check back with you.   Cheers, Ginny
Ch
Posted on Feb 12, 2009
  • 30 Answers
SOURCE: My Brother Innovis 4000D will no longer
if the machine is less then 5 years old and you have a proof of purchase it is covered under warr. only the labor is not still covered. It will need a new board to fix the problem
Posted on Aug 22, 2009
Testimonial: "Well, You pointed me in the right direction. Thankx for the prompt feedback."
Sewtech1
  • 69 Answers
SOURCE: I have a Innovis 4000D. The machine is shredding
Check that you have top tension and that the mahine is threaded correctly and that your bobbin case is not damaged.
Posted on Jan 20, 2010
Testimonial: "Thank you sooo much. I think I need a new bobbin case."
SOURCE: I have a Brother innovis 4000d sewing and embroidery machine. The embroidery pattern l am trying to sew has worked really well in the past, but now when it starts to sew it is not picking up the botto
try changing the needle
clean under the needle plate & in the bobbin area for loose threads or lint
rethread the machine top & bobbin
Posted on Apr 27, 2012
Testimonial: "Thanks so much for the help :)"
Brother innovis 4000D. Start stop buttons stuck in red, Machine beeping and screen light but blqnk
If your machine was serviced before purchase and now doesn't work, return it to be re-serviced and made functional.
Jul 05, 2016 | Brother InnovIs 4000D Computerized Sewing...
What memory stick will work on a innovis 4000d brother embroidery machine
Most memory sticks will work, but the smaller capacity sticks work the best.
If your stick has a lot of designs on it, the machine must read all the designs before bringing up any on the screen. Only keep a few on a tick at a time.
Sep 23, 2014 | Brother InnovIs 4000D Computerized Sewing...
Malfunction error PF-PM on Brother Innovis 4000D. HELP!!!
try unplugging it and letting it rest for 20 minutes? Sometimes that will reboot it.
Dec 10, 2013 | Brother InnovIs 4000D Computerized Sewing...
Brother 4000D innovis machine....when I turn it on, it will not start up..the lcd screen is faintly lit, and the machine just beeps
I had the same problem Machine off! I took off the rectangular cover on the right side (had to pry it carefully} GENTLY Pushed in connections of wires to board and then plugged in and it worked!! I happened a couple of times They must vibrate loose. All I has to take apart was that rectangle cover
Jan 18, 2013 | Brother InnovIs 4000D Computerized Sewing...
Machine keeps saying recheck/rethread upper thread
sounds like the computer motherboard could have malfunctioned
and needs to be checked
Nov 21, 2012 | Brother InnovIs 4000D Computerized Sewing...
My Brother Innovis 4000D will no longer "read" or recognize the flash drive or the designs on any "memory drive" or flash stick. How is this problem corrected? How costly is this kind of repair??
Aug 22, 2009 | Brother Disney PE-400D Computerized Sewing...
Brother InnovIs 4000D Computerized Sewing Machine Logo
50 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
