Question about BenQ Office Equipment & Supplies
My BenQ MX720 projector *powers down by itself after a few minutes even after I cleaned it and replaced the lamp. What else could it be?
*When I say "powers down", I mean the whole power down procedure like normal. The lamp turns off, fans run to cool it down, etc. So I'm thinking it's not a power supply issue. When this first started happening, I thought it was just a clogged air filter. Come to find out, it's a "filter-free" projector, so I just used some canned air to blow out the air intakes as best I could until no more dust came out. Started it up. Same problem. So when that didn't work, I ordered a replacement lamp, thinking surely that was the issue. No dice. What else could it be?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 781 Answers
The image is flicker, the light is twinkling, after seconds or minutes ,the projector power off.
1,the color starts to go out, it become the white and black,the image color is disappear.
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as 3 sesame seeds
I am an expert of repairing projectors for 19 years.
It is my pleasure to receive the message form you,
WhatsApp ID:+8613178867858
Skype:lampdeng@hotmail.com
Wechat ID:+8613178867858
Email:jerry@lampdeng.com
Email:lampdeng@hotmail.com
Mobile:+86 13178867858
http://www.lampdeng.com
Posted on May 31, 2019
SOURCE:
SOURCE: Projector shuts down after only a few minutes.
enter in Factory Menu
1. How to enter factory menu:
I. Hold press "UP" button until the "Lamp hours info." OSD display on bottom-right of screen.
Press keypad <Power> and <Blank> key simultaneously again, then enter Factory menu.
enter in fan menu and increse the speed of fans.
paul@ula.ve
Posted on Jul 02, 2008
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
SOURCE: Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Posted on Feb 08, 2009
jyackle5
  • 8197 Answers
SOURCE: Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Posted on Mar 12, 2009
SOURCE: panasonic projector keeps shutting off
Try this utube link. I did it and it solved the problem in about 30 seconds! Don't spend any money or send out your unit. This does it.
http://www.youtube.com/watch?v=6jGwB05_gdk
Posted on Jun 04, 2009
Benq MX761 stays on for only 2 minutes and then shuts down after genuine Benq lamp replacement. Picture flickers colour just before shutdown. Lamp timer has been reset to zero.
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Nov 29, 2014 | BenQ Projector Lamp for MX760 MX761...
BENQ 720 FACTORY SETUP
www.benq.us/product/projector/MX720
Aug 26, 2014 | Office Equipment & Supplies
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Start power on, a few minutes the lamp shutdown, tempreture and lamp signal alert.
Possible that the filter is clogged on the ventilation fan and must be cleaned and reset.
So remove the filter and clean , check for dirt or obstruction. Check the free flow of the fan to the lamp, if the fan is faulty or not running to the desired speed to cool.
Restart and allow the lamp to be cooled externally to confirm.
Apr 06, 2011 | BenQ MP512 SVGA 2200 ANSI 25001 22KG...
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
BENQ mp720 stops after 20 minutes and needs to
clean out the dust with canned air and make sure the fans work. if the lamp and power board can't cool down, it shuts down to prevent damage.
Sep 22, 2009 | BenQ MP720 DLP Projector
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
41 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
