Question about Nikon Coolpix 2100 Digital Camera
Nikon coolpix 2100 cameras won't turn on. new batteries installed, 256mb cf card installed correctly. Green light comes on for a second or two then goes off.
I just bought two of these cameras and neither will turn on but selecting setup works fine.
  • 24 Answers
Honestly: just throw it in the trash. You might want to tear it apart just to see whats inside.- it's that old. Please don't waste your time on it.
Posted on May 18, 2019
4 Suggested Answers
SOURCE:
Obertelli
  • 3006 Answers
SOURCE: New SanDisk 4GB CF Card - Coolpix displays out of memory
This is because the Coolpix 2100 and 31000 models cannot handle a card of that large a capacity. As it's only a 2MP camera anyway it doesn't need it.
The Coolpix 2100/3100 will usually accept up to a 512MB CF card, and 1GB Lexar CF cards up to and including the 24x WA write accelerated (although write acceleration itself offers no benefits on this camera). With Sandisk only a plain old and now obsolete SDFB allows a 1GB card to be used and the regular Sandisk Ultra (not Ultra II or later) will only work up to 512MB.
The camera was discontinued long before these much larger CF cards were released and Nikon no longer actively support the product so no firmware updates will be available. The hardware wouldn't support such cards anyway.
Compatibility chart for CF cards address below:-
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/26030/c/241/r_id/127673
Posted on Jul 04, 2009
SOURCE: Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
Posted on Mar 24, 2010
marked
  • 6487 Answers
SOURCE: I wish to use 1Gb
Sorry to say but this camera can only support a maximum 512 MB of memory card so the 1GB size will not be read by this unit.
Posted on Jun 08, 2011
My Nikon Coolpix S3100 won't turn on
I had the same problem, and many other people have had this issue. The camera sat for too long, and the battery fully discharged. It needs to be reset. In order to do that, remove the battery and memory card. Replace only the battery, and plug it in. You should see a green light flashing to the right of the LCD screen. That means it is now charging. Replace your memory card, and let it charge before trying to use it.
Apr 30, 2012 | Nikon Coolpix S210 Digital Camera
I just bought the JVC Everio GZ-MG330 and when I playback the video there is barely any sound even when I set the volume to the highest possible number. Does this mean the camara is no working properly.
Try resetting the unit:
To reset the camera
1) Close the LCD monitor to turn off the
camera and remove the power supply
(battery pack or AC adapter) from the
camera, then reattach it.
2) Select [FACTORY PRESET] from the
MENU.
If still no sound replace it...
Hope that helps........
Jul 19, 2008 | JVC Cameras
My moultrie trail game camera d-40 will not store pictures on memory card. I have tried multiple memory cards. The card I have been using is not very old and has worked fine until now. Camera is showing...
Is the small switch on the side of the SD card pushed up toward contacts? Has the card been formatted by a PC(A NO-NO)?
Remove card;turn camera on..go to setup; press up arrow once to get "DELETE ALL IMAGES NO?";press select button to get flashing "NO"; press up or down button once to change flashing NO to flashing YES; press select once...should get "DONE";press select until back in "SETUP...Turn camera off insert SD card and try again...may need new SD card.
Oct 24, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Everything seems to be working fine. timer, flas etc and it seems to be taking pics but when you check it there are none. have tried two different cards no luck any ideas
Remove card go to setup scroll until you get delete all images;select;up or down button to change no to yes;select..turn off and try card again.Have to delete internal memory to use SD card.
Sep 17, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Hi. i have sony w120. its not new, i bought it cca 3 years ago. I didnt use is for a quite a while (but my family did), so few days ago, i realized when i take pictures, pictures are somehow blurry,...
Please go to Setup menu and select Initialize option to reset camera to default settings that might solve blurry picture problem, if that does not help then its technician job to adjust focus of camera.
Thanks.
Aug 02, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
I wish to use 1Gb CF card of any make on my Nikon Coolpix 2100 digital Camera, which has effective 2 mega pixels. Will the Camera support it? Prasad
Jun 08, 2011 | Nikon Coolpix 2100 Digital Camera
Lens stuck outside. Sometimes says "access" on lcd.
Try these troubleshooting steps and check if it help to resolve it.
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
1. Press the Menu button on the Camera.
2. Then, select the SETUP menu and select the SETUP 1 option of the Camera.
3. Then, select the Initialize option to OK.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists then Service may requires to resolve it.
Aug 31, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Won't zoom :(
Option 1:
1. Please press the Menu button on the Camera.
Option 2:
Aug 11, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Nikon Coolpix 2100 Digital Camera Logo
20 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
