Where do I find the filter on the aquarius wf250 washing machine?
    Top Expert:
  • Washing Mach... Master
  • 29,187 Answers
6ya staff
SOURCE:
Lloyd
  • 89 Answers
SOURCE: Where is the filter on the Hotpoint Aquarius
Filtet access at the rear of the machine behind access panel, Remeber to remove the plug from the socket before removing the rear panel
Posted on Jun 10, 2009
hotpoint jon
  • 353 Answers
SOURCE: Fitting pump to hotpoint WF250
disconnect the machine hoses and all drain put it on its side you will see the pump usually help in place by 2 screws/ 2 hose clips/ 2 wire thats it pump should cost no more than approx.18.00
Posted on Jun 30, 2009
Anonymous
  • 5 Answers
SOURCE: does my hotpoint washing machine aquarius wd64
if your hotpoint has no obvious filter ( small flap on front ) its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.
pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully andd make sure its all back together as before.
Not easy but the blocked filter causes so many hotpoint issues. Its a pain the way they have built it inside the machine rather than making it user friendly.
Posted on Sep 17, 2009
techster04
  • 155 Answers
SOURCE: where is the filter on a hotpoint aquarius 1000
The filter is underneath the machine,tilt it backwards look underneath and
you will see a rubber pipe with a plastic inner with a clip on the end.
Undo the clip and slide the filter out.
Posted on Apr 06, 2010
prem mathew
  • 662 Answers
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
I have a hotpoint WF250 1500 spin. It wont drain. i cleared filter but still not drain when restarted. What would problem be? i cannot find the user manual.
Could be a blocked pump or outlet hose, remove the hose and lay it down to floor level to drain off water, then remove lower rear cover of washer, and remove the hose from the pump, see if it nis blocked, couls also be a faulty pump.
Nov 30, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius wf250 won't do anything it lights up with wash symbol but doesn't fill or wash it doesn't make no noise or anything please help
open the top of washing machine and near the door on right side is a connector loose just push in and will work fine.
May 10, 2009 | Washing Machines
How do i change the brushes on my wf250 hotpoint aquarius machine
your machine may have a 'brushless' motor. but generally hotpoint motor brushes are fixed with 2 screws and are in ablack plastic cover and can be seen if you tip your machine back against a wall and look underneath. the motor being at the bottom of the drum, you could remove them wuth a long magnetic screwdriver.
Feb 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
May 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
