Hi when i turn on the technogym old model it spins really fast i cant slow it down D140-ING-0E
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: maytag performa washer
Hi Folks,
I'm guessing both of these problems are related to the belt slipping. There are several points to check.
  1. the belt tension. I'm not familiar with the exact details of your machines, but the usually have a an extra pulley with a spring attached to give the belt tension. Alternatively, the motor is mounted on a movable frame that is held by some springs. These springs give the belt tension. In either case check the freedom of movement of the tensioning arrangement and the springs are providing the necessary tension to the belt.
  2. Glazed belt/pulley - if the belt has been slipping it will polish the pulleys and this will reduce the friction necessary to drive the machine. To fix this the belt should be replaced and the pulley surfaces roughed up with some wet/dry emery paper (not too rough or it will wear your new belt out).
  3. Belt is too old - the rubber becomes hard and brittle and ends up with the same effect as Glazed belt/pulley above. The fix is as per 2 above.
Good luck
Bob Thompson
Posted on Jan 01, 2008
Anonymous
  • 126 Answers
SOURCE: Hoover sttem cleaner
The brushes spin by virtue of an air driven turbine. This turbine uses a little of the motor suction to turn a large fan which turns the brushes. If you look behind the clear glass window on the front right hand side of the machine, you will see a screen which acts as a filter to keep debris out of the turbine. If this screen becomes clogged, it will affect the flow of air to the turbine and the brushes will slow down or stop all togeather.
Also, if the lid of the recovery tank is not on correctly, the suction will be compromised and the brushes will not turn and the machine will not pick up water off the carpet.
Posted on Feb 04, 2008
Anonymous
  • 113 Answers
SOURCE: Washing Machine doesn't spin fast enough
Most likely needs a new clutch. www.washermd.com dave
Posted on Jan 14, 2009
Charles Moore
  • 314 Answers
SOURCE: flasher is screwed up
This sounds like a bad flasher unit. Simply by replacing this unit should fix this problem. Usually they are located on the top of the steering wheel beneath the trim. You have to disassemble the trim around the steering column.
Posted on Jun 09, 2009
Anonymous
  • 82 Answers
SOURCE: Washer spins but really really slow, not fast
it can be the pump if it does not get the water out fast it will slow spin best way to check put it on spin with nothing in and watch it if it does the same then the moter is faulty change it try ebay for replacements
Posted on Jul 29, 2009
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
I have recently replaced the bezel and LCD cover of my Dell 1737 laptop. Upon turning ing it on, however, the fan spins very fast and of course is very loud. I was wondering if anyone may help me...
its normal for fan to turn really fast during start-up but if it stays that way means, your unit is very hot and the system is continuously trying to cool it down. open the bottom cover and clean the vent this might fix the issue apply thermal paste of high quality if you have some. it can greatly reduce temp up to 5 degree instantly. as to your question whether its fan or heatsink problem, i assume it is fan. heatsink is passive and less likely to have problem
Aug 06, 2013 | Dell Studio 1737 Laptop
Turntable spins to fast
The motors are a common problem with this
model! Replace it to correct but I suspect the
motor regulator ic which is not avalible is the
real problem!
Apr 02, 2010 | Sony PS-LX250H Turntable
Washer spins but really really slow, not fast enough to extract water
Jul 28, 2009 | Speed Queen ATS90AWN Front Load Washer
Motor is sluggish, Necchi Model#4795
Set machine to wind the bobbin to check for how fast the machine will run. I believe it will run fast or slow according to how hard you depress the foot control. If it runs fast and slow you have a problem in the machine. Most likely the machine, if turned by hand, is hard to turn and it needs to be professionally serviced. before it is ruined.
sewman7
Dec 29, 2008 | Sewing Machines
Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
Jul 17, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
