Question about Simbans Tablets & eReaders
Where do you find the warranty to fill out on a Simbans TangoTab 10 in.Tablet 2 in 1
I hold my power button and volume botton but my simbans tablet wont turn on even when charged
Sounds like the power button switch has given up on you. With a lot of care and time, you can fix this yourself for a few dollars if you buy the part and tools on eBay, or you can just take it to a repair shop.
Jun 03, 2018 | Simbans Tablets & eReaders
I have a simbans tango tablet gifted at xmas and the sound is not working.I can hear with headphones. What to do? I'm in Canada.
swipe down from the top and check the settings in "audio profiles" See if the speaker is muted.
Jan 25, 2018 | Simbans Tablets & eReaders
How can I download a driver from Simbans so I can download and upload to my PC?
You just connect it with you USB cable and transfer using Windows Explorer. It will be shown as a Removable Drive.
No drivers or software exists. Brand leader is iPad, which does have some capabilities via iTunes.
May 05, 2016 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
How do I rest and unlock my tablet without loosing any data?
If you have little experience with the modification of Android devices then it's unlikely that you will be able too, but if you have a micro SD card in then you can pull it and plausibly save your pictures
Feb 21, 2016 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
How do I fix a forgotten drawn pattern?
I can help you reset it, but you will likely lose your photos, if interested send me make/model at dougkling6@gmail.com
User manual simbans ultimax 10'' tablet
Your manual is here.
Turn your device on and off To turn on your device, press and hold the power key.
To turn off your device, press and hold the power key, and then tap Power off?OK.
Manuals
Dec 29, 2015 | Simbans Tablets & eReaders
Need to reset simbans ultimax tablet pc due to space problems. get message of 'not enough storage to download app'. how do I do this?
To reset your tablet you need to go to setting then find backup & reset and when you are there you should click on factory reset
Aug 15, 2015 | Simbans Tablets & eReaders
I am sure this is the right pattern to open tablet. I have not used the tablet for quite some time, the date is back to Jan. how do I get to use my tablet ?
Hi Wanda,
First make sure that it is fully charged before you use it. Then push the button on the side. Here is a youtube video on how to use it:
http://www.youtube.com/watch?v=b210pnWgKMM
Best regards,
Bill
Oct 25, 2014 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
How do I unlock my tablet/
Whats your tablet brand and model ? Do you want to unlock your tablet from carrier lock? If so, use unlock code . You can get it from any of the online vendors like SimpleUnlocking.com to unlock it .
Can't get my pattern to open tablet
As you probably realise you are entering the wrong pattern! You will have to wipe everything with a factory reset back to when new!
Oct 24, 2014 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
Tablets & eReaders Logo
Top Simbans Tablets & eReaders Experts
Andrew Taylor
Andrew Taylor
Ken Strite
Ken Strite
 Mikey
Mikey
Are you a Simbans Tablet and eReader Expert? Answer questions, earn points and help others
