Question about Sony Televison & Video
My sony Trinitron kv sr3am30a screen has black on the sides the picture is in the middle as oval shape help please 083 393 7949
SOURCE:
techman
  • 3130 Answers
SOURCE: SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Posted on Mar 25, 2006
  • 4234 Answers
SOURCE: Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Posted on Jul 14, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
Posted on May 19, 2009
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
  • 115 Answers
SOURCE: Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Posted on Oct 01, 2009
Testimonial: "Thanks for the amazingly quick response. This is very helpful information."
Factory reset sony tv
Sony Google tv can't make factory reset went I try I just have a black screen help please
Jan 09, 2014 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony Wega Trinitron TV image has shrunk?
Check its main power regulator section circuit for any loose solder terminals. Low power regulator voltage output is the problem to your TV.
Nov 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The left and right sides are black and the picture is squeezed into the middle on the screen. i think it is called pin amp
This problems the Horizontal IC is dead and some of it capacitors too.Might even have the FBT dead too.If still have the same problems,after the "H" IC and those capacitors are replaced.
Sep 09, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron
check the heater as your tv is ON, there must be a yellow light at the rear of the CRT tube. If the heater is ok then check the IC jungle side. resoldering the leads sometimes will solve. If not refer to your local Tech.
Jul 31, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Picture suddenly turned dark
hi the picture tube of ur tv has got damaged and it badly needs a replacement.. so its better to replace ur picture tube..
thank u rate me!!
Feb 08, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron wega KV27FV310
Sounds like a problem with the vertical circuit. If yuo can solder and are comfortable with working inside the set, you may be able to repair this.
Keep us posted.
Dan
May 23, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony WEGA KV-36HS500
you may have cracked the circuit board when moving , sounds like a bad vertical circuit. look for bad connections around vertical ic or flyback transformer
Aug 19, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
