Question about Sony Televison & Video
My child played and i m getting a wall paper image in my sony bravia w66f 52' tv. how to get rid of this image..when i take hdmi2 or nything this image covers and all my thing runs in background
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: I can't get rid of the information bar across the top of my TV
Press " i " (information) button on TV remote and on-screen display will disappear.
Posted on Dec 29, 2008
  • 2920 Answers
SOURCE: Sony 52 inch projection Screen keeps shutting off.
not if it keeps repeating the same cycle over and over..it cost 300 once and if you have it fixed again thats another 300 and if it happens again so on and so on....
Posted on Feb 04, 2009
  • 203 Answers
SOURCE: sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
Posted on May 04, 2009
SOURCE: Cannot remove tv guide banner from Sony bravia 52'
Click on the display button (upper left corner) as a short term fix - it will turn it off immediately - not sure of how to permanently solve this though.
Posted on Nov 07, 2009
  • 65 Answers
SOURCE: slow moving image sony bravia KDL32M3000
This is actually a common problem with this model, and its surprising that it really does look like a video board (BM board) problem. It is actually a problem with the panel itself.
Here is the fix:
http://www.youtube.com/watch?v=9UrTVEC5LkA&feature=related
This guy was kind enough to post it. I recently did the repair on a KDL-32M3000 and it worked like a charm. Took surprising long, but worked like a charm. I didn't have a 10 Ohm resistor laying around, so I used 2 x 4.7 Ohm resistors in series.
Posted on Dec 09, 2011
My sony tv has a line across the screen that says bx42, full hd1080p, digital noise reduction, usb play, hdmi2, bravia sync, pc input, 24p true cinema and i cant get rid of it.
Hi mike harris,
i think your TV is on demonstration mode.
To turn off the demo mode, press and hold the HOME or MENU button on the TV for more than 10 seconds. The messageDemo mode: Off will appear on the screen.
NOTES:
Mar 02, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
52'' Sony Bravia will not turn on
Its fixable problem like power supply board replacement will solve the problem.
Unplug tv from wall socket for couple of minutes, replug back in and turn it On.
If problem still exist then most likely power supply got fired and will be replaced, local tv repair shop will help you to replace power supply board.
Thanks.
May 02, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Sony 52 inch XBR with bands of ghosted images
Its a TAB bond Problem with the LCD. You can take apart the TV and install a rubber Bumper to put pressure on the TAB. TAB bonds always get worse... I dont know how long it will solve the issue... but u can get a little more life out of it.
Rember when working with the TV the voltages can kill!!
Heres a link to see someone fixing.
I have the same TV...same problem...common problem...unless u ask Sony.
Feb 14, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Hdmi connection blueray to sony tv bravia.sony bd. pluged to hdmi2 unable to get picture. hdmi1 being utilize by cablebox. should i change hdmi setting on tv, how is that done.
there should be a imput button on original remote. just push it then scroll to hdmi2, then enter should give you picture if not they will be an imput option under your menu options
Feb 09, 2010 | Sony Blu-ray/dvd player BDP-S1
Unstable 52'' TV. don't want to mount on wall
There is support belt supplied with TV that need to be fixed on TV stand base and shelf / base cabinet to avoid any toppling over.
Please check user manual of your TV, procedure is written there.
Thanks.
Jan 03, 2010 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
52' sony bravia
hi. its enough that you can change the display alone for your sony tv.
Dec 26, 2008 | Sony BRAVIA KDL52XBR2 Television
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
