Question about Westinghouse Televison & Video
I have a Westinghouse tv the volume does work but not right it states it’s on 50 but it definitely is not I want to turn it up but I can’t this just started happening 2 days ago I’m going crazy trying to resolve this
SOURCE:
SOURCE: Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Posted on Jan 06, 2009
  • 6982 Answers
SOURCE: turn the key and nothing happens,no crank,no sound,no start
It seems that you have a loose wire, bad connector or perhaps the main computer itself that is causing a problem If the shop is not seeing any codes, or codes come and go, likely I'm right...but someone is going to have to actually do some intensive testing to find the real cause. You can likely get another computer from a local scrapyard far cheaper than what the dealer will charge you...as far as wiring, you need a good accurate schematic a good volt/ohmeter and lots of time to trace wiring. When checking connectors test the pin, then probe the wire going into the pin...often the problem is where a wire meets the backside of the pin, either corroding or breaking..This also applies to any modules such as the security system...what you see on the dash does not always tell you that connection to components is good. This is not a "fix, but rather, a direction to go in. (exactly what I"d need to do if I was there)
Right now, everything is suspect including fuel system, till you rule it out!!!
Posted on Jun 05, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
SOURCE: Westinghouse 32 in LCD TV
I have had this problem now for about six months with my Niko OPT-3211W. After replacing the Inverter card, VIT70002.00 as suggested nothing changed. I then read that it may be a couple of capacitors in the power supply, but I do not have the skills needed to replace them, nor do I want to pay to fix it. The solution is simple... turn on the TV and wait two to five minutes, then turn off the main power. I suggest using a power strip. Then turn the power back on in two to five seconds. The TV will come back on and it works great from then on. I thought that it was a freak thing, but it keeps working.
Posted on Aug 23, 2009
SOURCE: Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Posted on Jan 18, 2010
How can i disable the control buttons (volume and input) on the tv and use remote?westinghouse sk-32H640G
Sounds like main system control memory IC fault. Contact any service technician to replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 29, 2014 | Westinghouse Televison & Video
22" flatscreen LCD Westinghouse TV.
try use a lowest resollucion 720p and after change to 1080
Sep 20, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
I have a Westinghouse SK-26H240S LCD TV. It is about 3 years old. I never had a problem with it until a few days ago. It turns on but I get no picture or sound. The screen sometimes has some horizontal...
This is definitely a problem with the LCD controller of the tv or the LCD panel itself. However if I were you I would hope that its just the controller(which costs about 50$) and go ahead with the replacement to see if that resolves the problem
Mar 16, 2011 | Westinghouse SK-26H240S Television
My westinghouse tv has a crack inside screen with different color of stripe.and only the upper half of the screen works
The LCD panel has physically broken and is impossible to repair. The only fix is to replace the complete panel, but it will cost more than buying a complete new tv, sorry.
When you buy a flat panel tv you are effectively buying the panel at a huge volume discount and all the other parts which turn the panel into a functional tv are effectively bundled for free. Buying the flat panel as a spare part does not benefit from the same economy of scale and so even without labour and shipping charges, they can actually cost more than a brand new tv and definitely cost more than a secondhand, used, tv.
Sorry it's not the answer you wanted, but please take a moment to rate my reply.
Sep 24, 2010 | Westinghouse SK-32H240S Television
Televison & Video Logo
23 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
