Question about HP Office Equipment & Supplies
After changed an ink cartridge Igot Error 0x610004a. I turned it off and on and unpluged it many times but doesn't respond. It says paper jam, but it's not. I opened and closed tray many times.
I tried each of those actions many times. It says I should calibrate it, but doesn't work when I indicate OK. It seems to be stucked and each indications goes from one screen to another without taking my indications and actions.
SOURCE:
  • 401 Answers
SOURCE: Signal Lights - flasher...
Hi it sounds like the multifuntion switch
never had one on a monte carlo before but lots of grand am and malibu
hope this helps
Posted on May 13, 2009
lemmingleejn
  • 173 Answers
SOURCE: sunroof stuck in the open position. can;t close.
The problem is probably the 'flap' of metal that's popped up, just above the where the handle is.
The runners/rails have undoubtedly corroded, and now there isn't anything to pull it down.
Luckily, as a 'Get the roof shut cos it's p*^%g
down' solution,,.
You can just hold your finger on the flap, to hold it down, in between the sunroof, and hole as you shut it.
Just remember to remove your finger Before you finish closing the sunroof.
Happy motoring.
Posted on Jul 24, 2009
  • 27 Answers
SOURCE: high beam indicator remains on all the time, turns
bad earth r dodgi indicator stalk
Posted on Sep 30, 2009
SOURCE: power windows and indicators have failed at same
Even I am having the same problem. In addition to power windows and turn signal, the seat belt sign is also not working. Let me know if you find otu something and same with me, if I figure something out I will let you know
Posted on Feb 01, 2010
dttech
  • 4803 Answers
SOURCE: When I open the door
It is normal operation for the odometer to light up with the driver's door being opened. It is not normal for the chime to go off. The "Key-In Switch" in your steering column is malfunctioning. The body control computer "Thinks" the key is in the ignition when it is not. It usually requires a new key tumbler assembly to fix this.
Posted on Dec 26, 2010
Can you please help me with the error 28113 ricoh sg3110dn
Paper pinch roller is having some problem may be there is a paper jam or Cartridge try to remove all papers then remove the ink cartridge pull out the power wait for some time ,put back the paper without ink and paper
check if the error is changed if yes replace your ink if still there check for any paper jam clean it all properly and start again.
Jul 07, 2014 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Does not print, responds with paper jam. No paper jammed. Clean sheet of paper passes through. Could a buildup of dust be the problem and its age. Tried cleaning roll by command and changing the ink. I...
What you could try is let the printer to reset.
Remove both ink cartridges.
Close cover and turn off printer.
Unplug printer from electrical outlet.
Wait 15 minutes. This will let the printer to clear memory.
Plug printer back in.
Turn on printer, printer would cycle to the start position.
E5 error would appear.
Install ink cartridges.
If nothing is in the printer that prevent the printer from recycling.
There should be no paper jam error.
Jan 04, 2011 | Canon PIXMA MP170 All-In-One InkJet...
Canon mp 170 printer ask to clear paper jam while there is no paper jammed.tried these1-pass a cardboard 2-reset printer by unplugging it for a minute.exactly wich part of the printer sense the problem.
Unplug the printer for at least 2 minutes from the wall.
2. Plug the printer back in but leave the printer turned off.
3. Enter Service Mode
a. Hold Stop/Reset button and the Power button for 5 seconds
b. Release Stop/Reset button but continue to hold Power button
c. Press Stop/Reset twice
d. Release the Power Button
e. Wait for the light to stop flashing. The printer is now in service mode. The display may be blank or simply read "Canon" during this time.
4. Do an EPROM reset.
a. Press the Stop/Reset button 3 times.
b. Press the Power button twice. The printer will save the changes and then it will reboot. A little cd/dvd icon will appear in the LCD screen.
3. The printer will probably now require the same setting up as when you first unpacked it. That is, you will need to select a language and let the printer do a head alignment.
The printer is now enabled.
MP150/MP160 ERROR CODES:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 29, 2010 | Canon PIXMA MP170 All-In-One InkJet...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer not responding
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E35 15 USB Host VBUD overcurrent error - USB
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam error message
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
- unplug cable
- plug cable
Run the software.
oke
Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
32 people viewed this question
Clive
Clive
Thomas F. Schneider
