Question about Mitsubishi 3d Ready Wd-73c10 73" 1080p High Definition Flat Panel - Dlp - Tv
Code 44 Mitsubishi tv 73c10
Tv blinks code 44
SOURCE:
SOURCE: innovage jumbo remote code for mitsubishi tv
**** a chod
Posted on May 17, 2009
SOURCE: mitsubishi tv blink code 4
mitsuhishi WS-55711 Serial code 63412 no power and green lights keeps blinking
Posted on Aug 24, 2009
SD Tech
  • 14553 Answers
SOURCE: I have a mitsubishi model wt42311 TV that will not
2,2 is short protection---it means one of the two soldered in fuses that protect the convergence circuit is bad.
What it really means is both of the STK-392-110 convergence chips this set uses need to be replaced---one of them got the fuse.
May be a do it yourself job if you know how to solder etc. Total parts cost should be under 30 dollars.
Let me know if I can assist you further.
SD TECH
Posted on Jan 23, 2010
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Posted on Mar 25, 2010
SOURCE: mitsubishi WD-65737 DLP TV. TV powers on, green
I had exactly the same thing happen..I contacted Mitsubishi and they said the software needs to be updated..they are going to send me the link to download the software.
Posted on Dec 29, 2010
REPLACE BOTH POWER BOARDS ON A MITSUBHIS1 60738 IM GET 4 BLINKING YELLOW AND 4 RED I NED TO NO WHAT THIS CODE MEANS PLEASE HELP IVE DONE EVERTHING I CAN.
That is a 44 error code. It means that the LVDS cable is not being detected. Make sure that you got it connected securely and that it didn't get torn. I hope this helps.
Nov 30, 2015 | Mitsubishi WD-60738 60 Projection TV DLP...
I have a mitsubishi hd 1080 65315 model and the code is 23 what is the problem.
Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
www.stereoandvideorepairco.com/.../MitsubishiShutdownTroubleshootin...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
forum.eserviceinfo.com/viewtopic.php?t=81051
Oct 24, 2010 - 10 posts - ‎4 authors Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
Oct 19, 2015 | Mitsubishi Televison & Video
What is Mitsubishi DLP TV error code 44?
That is an Open(blown)
Check for open F9A06 on the Power PCB
Sep 15, 2015 | Mitsubishi Televison & Video
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Mitsubishi error code DLP TV
CONTACT MITSUBISHI TECH SUPPORT
Jan 31, 2014 | Televison & Video
Wd-73c10 blinking red and yellow
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 11, 2013 | Mitsubishi 3d Ready Wd-73c10 73" 1080p...
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
What does it mean when the status light is blinking red on my mitsubishi wd-62526
When the status light is blinking push the device and menu buttons on the tv at the same time and hold for 5 seconds or more. The red light will then blink a code. It will blink like 3 times, pause, then blink like 5 times. That would be a code of 35. It may blink one time long, then two short blinks. That is not a code blink but indicates another problem. Do a search for the service manual for your tv on the internet and look up the code. Sometimes it is as simple as a dirty fan that won't turn any more. But by knowing the codes you will know if you need a technician or if it is something simple.
Oct 07, 2011 | Mitsubishi WD-62526 Projection TV
HELP
how many times does it blink it should blink a two digit code. let me know the sequence of blinks as it should be a self diagnosis code
May 20, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 3d Ready Wd-73c10 73" 1080p High Definition Flat Panel - Dlp - Tv Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
