Question about Sony Televison & Video
Program remote to work a sony dvd home theater system
I have the AH59-0163f remote . need info how to program it
SOURCE:
techman
  • 3130 Answers
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
Posted on Oct 15, 2007
minteker
  • 52 Answers
SOURCE: Remote code for Sony Home Theater
Here's a link to the user manual for the remote. There's a section with codes for programming your devices.. Also, it says, if code isn't listed, there is a "code search" function on the remote..
Posted on Mar 19, 2008
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Posted on Jul 02, 2008
SOURCE: Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
Posted on Apr 28, 2009
SOURCE: need to program 311w U. remote to RTD215 home theatre
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Posted on May 03, 2009
Need help programming rca universal remote RCRN06GR to a RCA dvd/blu ray home theater system RTB1023. Tried several codes and none work
Send the Universal Remote back and buy one for that unit.
Buy RCA RTB1023 REMOTE -RTB1023 Blu-Ray DVD Player Remote ...
https://www.replacementremotes.com/rca/buy-rtb1023-remote-rtb1023-blu-ray-dvd-p...
RCA RTB1023_REMOTE Blu-Ray DVD Player Remote Control ... RTB1023 600W BLU-RAY HOME THEATER SYSTEM REMOTE CONTROL ... as possible on the blu ray player although buttons are missing on this replacement remote.
RCA RTB1023 REMOTE (p/n: RTB1023) Blu-Ray DVD Player Remote ...
https://www.walmart.com/.../RCA-RTB1023-REMOTE...RTB1023-Blu-Ray-DVD-Pla... US$29.95 - ‎In stock
Buy RCA RTB1023 REMOTE (p/n: RTB1023) Blu-Ray DVD Player Remote ... DVD Player RTB1023 600W BLU-RAY HOME THEATER SYSTEM REMOTE ...
rca dvd blu ray home theater system rtb1023 replacement remote Google...
Jul 15, 2018 | RCA Televison & Video
I have a panasoniic universal remote coontrool dvd system eur7722xgo and i want to program my sony dvd home theater system dav-dx250 with it
If you have a universal remote, you can try using its code search feature to find a code that will control your Sony system. If you search through all codes stored in your Panasonic remote without success, you may have to try another universal remote. Programmable remotes vary in the codes they store.
Jan 04, 2015 | Panasonic Universal Remote Control For...
I have a Sony theater reciever that I bought off eBay with no remote. So I looked around and Sears was selling a Sony Universal remote RM-VZ220 saying it was compatible with my Sony STR-K670P AM/FM...
1. Make sure you have good batteries in the remote and they are installed properly.
2. Press the DVD button on the second row of the remote, then check if the Power and other buttons on the remote work with your system (it probably won't since the factory setting is for a Sony DVD player, not a home theater system).
3. If it doesn't work you need to find the correct code number for your system and enter it into the remote. Press and hold the SET button for more than 3 seconds until the SET indicator lights up. Keep holding the SET button down and press the DVD button, then release both buttons. Then enter the code 31622. If you have done this correctly the SET indicator flashes 3 times, if not start over.
4. See if the remote now controls the theater system correctly. If not, repeat the above procedure #3 with the following codes one at a time until you find one that works: 31558, 31658, 31758, 31822, 31858, 32522.
May 23, 2014 | Audio Players & Recorders
Motorola remote and sony home theater system code
you may need to set it up as two devices program a code for DVD to turn the unit on and off and a program and auxiliary code so that you can control the volume then you can teach the remote to use the auxiliary volume without having to press the aux button each time
Nov 10, 2013 | Sony BRAVIA Televison & Video
I want to program my home theater system with my dvd player\r\ndvd player is a blu ray remote is sony rmt-b104a sony htss360 is home theater system
http://esupport.sony.com/perl/model-home.pl?mdl=RMTB104A
GO TO THIS DOWNLOAD FROM SONY AND PUT YOU REMOTE CONTROL FOR YOU SEARCH YOUR CODE AFTER YOU DOWNLOAD YOUR REQUIRED MODEL.
SINCERELY.
E.CUADRA
MANAGUA, NICARAGUA.
Jul 26, 2011 | Sony rmt-b104a Remote Control
I Need the five digit remote code for a RCA RTD215 DVD player to program into a universal remote
What is the make and model of the universal remote? They each have their own sets of codes, so there's not a code for your DVD that works with all universal remotes.
Post back the make and model info using the "add comment" button, and I'll do my best to look up RCA DVD player codes for it.
Apr 15, 2010 | RCA RTD215 Theater System
Program code for sony home theater DAV-DX250
my home theater model dav dz270 but my remoteis missing please help me what is the remote number
Mar 27, 2010 | Sony DAV-DX250 System
Need remote controller
Check out the Logitech Harmony series of remotes that can be programmed to operate all your electronics from activity-based buttons.  For example pressing the "Watch Movies" button will turn on the TV and select the DVD input, turn on the home theater, and turn on the DVD.  Then the buttons on the remote will control the appropriate device (home theater for sound, play buttons for DVD, etc.)
Go here for info: http://www.logitech.com/index.cfm/remotes/universal_remotes/&cl=us,en
Jun 02, 2009 | Insignia 42" LCD Flat-Panel HDTV
I just bought a Sony Home Theater DAV seris but there was no remote. Are there buttons on the reciever that work like remote buttons?
most all theater systems come with a remote and it,s odd that your,s did not, usually their are certain functions that you can control from the head unit ,but nowadays you can program a universal remote to your brand that will be able to control the functions of your theater system ,but to make things easier, call the customer service dept of sony and tell them your model# and purchase it direct from the manufactuer, this remote will have set-up functions for your dvd menu,s and will be easier then having to get up off the couch to change settings , thank you ,hope this helped glenn
Mar 03, 2009 | Sony BRAVIA® DAV-HDX277WC Theater System...
Televison & Video Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
