Question about Cell Phones
Service menu for lt 32n330 - Cell Phones
Access service menu on jvc LT-42P300
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 11, 2014 | JVC LT-42X579 42 in. LCD TV
Tip
Sony Ericsson Secret Code
<span><br />IMEI number: * # 0 6 #<br /><br />Software version: &gt; * &lt; &lt; * &lt; *<br /><br />Default Language: &lt; 0 0 0 0 &gt;<br /><br />Enter to phone menu without SimCard - after Wrong PIN: press NO: * * 0 4 * 0 0 0 0 * 0 0 0 0 * 0 0 0 0 #<br /><br />Information about SIMLOCK: &lt; * * &lt;<br /><br />Sony Ericsson Secret Menu: -&gt; * &lt;- &lt;- * &lt;- *<br /><br />(-&gt; means press joystick, arrow keys or jogdial to the right and &lt;- means left.)<br /><br />You'll see phone model, software info, IMEI, configuration info, sim lock status, REAL time clock, total call time and text labels.<br /><br />You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and ******** tests)<br /><br />IMEI Number: *#06#<br /><br />Lockstatus: &lt;- * * &lt;-<br /><br />Shortcut to last dialed numbers: 0#<br /><br />Shortcut to sim numbers: On main menu type a number and press #<br /><br />If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press &lt; 0000 &gt; . &lt; stands for left arrow button or joystick and &gt; stands for right arrow button or joystick.<br /><br />note! Try these codes at your own risk! We don't accept any complaints. Some of these codes may not work in your mobiles.</span>
on Jul 11, 2011 | Cell Phones
How to reset konica bizhab 164 m2
press menu quick setting << quick setting <> (service mode) go to service choise and go to maintenanc 0 ok press back IU LIFE STOP MODE press continues . press back go to clear data go to maintenac clear and supplies clear ok power off and on
May 31, 2014 | Konica Minolta Office Equipment & Supplies
I formatted but its appear the same thing
Hello, Please do it and reply me whats the problem ,
> * > means press joystick or arrow keys to right
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
The Service Menu will appears containing following information !
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
b. LED/Illumination - *This test is very cool
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
i. Joystick Counter*
Lockstatus:
Secret Games: Snake on the T68
Go to Erix and then on the main screen press 123 and you will be taken to the game.
Reply me
Jan 26, 2011 | Sony Ericsson K790i Cellular Phone
How to change my security code but i didnt know my old password to chage it
2. press *
4. press *
6. press *
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
Lockstatus:
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | Sony Ericsson K550i Cellular Phone
How to format my sony ericsson w350i phone internal memory
HELLO, Sony Ericsson Secret Menu:
2. press *
4. press *
6. press *
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
Lockstatus:
Hope this helps
Jan 26, 2011 | Sony Ericsson W350A Cell Phone
How to open wap connection
Internet access setting for Motorola RAZR V3X : 1. Go to menu => Web Access => Web Sessions => new entry
2. Fill in a account name
3. Select Access Point settings
4. Set service type to WAP
5. Enter GPRS access point (APN) 6. Enter User name and Password
7. Select myGlobe GPRS.
8. Press menu
9. Select set default
Note : you have get valid names /codes form service provider of number 2,5,6. Different operator will has different setting.
Dec 04, 2010 | Motorola Mobility RAZR V3x Cellular Phone
Sda
To change the device control panel display language
1. Press MENU/ENTER.
2. Use the < or the > button to select Common settings, and then press MENU/ENTER.
3. Use the < or the > button to select Language, and then press MENU/ENTER.
4. Use the < or the > button to select the language that you want.
5. Press MENU/ENTER to save your selection.
The device automatically restarts.
If this does not work you can always reset the printer to factory settings,but keep in mind you have to set it up again.
To restore the factory-set defaults
2. Use the < or the > button to select Service, and then press MENU/ENTER.
3. Use the < or the > button to select Restore defaults, press MENU/ENTER, and then press
MENU/ENTER again to confirm your selection.
Hope this helps good luck thanks.
Mar 23, 2010 | HP LaserJet 3015 All-In-One Printer
How to format my w200i cp???
I dont think u can by any code, any way these are the codes that u can see internal info
Sony-Ericsson
> * < < * < * - Service menu
< * * < - Lock menu
Nov 21, 2009 | Sony Ericsson W200i Cellular Phone
Service Menu
You have to press >*<<*<* to access the service menu ...
Jun 20, 2009 | Sony Ericsson K550i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
