Question about Kyocera Cell Phones
Kyocera duraforce pro bluetooth keeps turning off after 2 hrs
2 Suggested Answers
SOURCE:
  • 3600 Answers
SOURCE: How to tune and adjust carb settings on Lawnboy 2
First remove the inline fuel filter in the tank and replace it, before adjusting the carburetor. Also Be sure the linkage from the governor and to the engine has not broken or fallen off, next check the fuel pump bulb by removing the air cleaner and pushing the bulb in if you see a stream of fuel each time you push the button it's fine otherwise the check valve may be dirty and you will have to clean it to fix the problem. Also make sure the air cleaner is clean. After you check these items then you can adjust the fuel mixture screws turning the air mix valve firs and getting the motor to smooth out at low speed. Turn 1/8 of a turn at a time till you get the desired running range. Also check that the spark plug is nor dirty if it is clean and re-gap it if the electrode is worn out then replace the plug.
Posted on Sep 23, 2009
Just boight a duraforce kyocera and it came with a lock screen activated, cant get past it
You will have to Factory Reset it.
Power it down. Press and hold the power button and volume up button until you see the Recovery Console.
See the link for videos
kyocera duraforce hard reset Google Search
Mar 20, 2018 | Kyocera Cell Phones
Can I get a credit card reader for my Kyocera 6810 DuraForce Pro?
Square Square Credit Card Reader - Verizon Wireless
https://www.verizonwireless.com > Home > Card Readers > SquareThe Square Credit Card Reader is also compatible with select Android devices (click on compatibility tab for complete list). There's no need for complicated .... The email I received touting this device clearly indicated the square reader would be compatible with my cell phone. It wasn't. ? No,: I do not recommend this product.Missing: 6810
Feb 04, 2018 | Kyocera Computers & Internet
How do i hard reset my kyocera duraforce its locked an i dont rember the passwoerd or the email used on this phone
power off. press volume down and turn on the power select recovery option and select wipe data factory reset
Oct 12, 2017 | Kyocera Cell Phones
Life wireless apn settings for at&t kyocera duraforce e6560
The best place to get these settings is from your service provider. Call up on their customer care hotline and ask. They'll send an SMS containing the settings.
Jun 20, 2017 | AT&T Cell Phones
How do I change out the charging port in a kyocera duraforce e6790?
almost impossible to DIY hand solder to replace a charge port
recommended fix is
buy a used phone that works and fit your sim card
or
replace the internal printed board of the phones internal construction
Sep 02, 2016 | Kyocera Cell Phones
My kyocera duraforce phone will not charge
change the charging port of the phone
Mar 12, 2016 | Kyocera Cell Phones
How do i find a user manual for my smart phone
PDF]KYOCERA DuraForce User Guide
https://www.kyoceramobile.com/duraforce/DuraForce_User_Guide_ATT...
KYOCERA DuraForce. User Guide ... Charge the Battery Wirelessly .......... ........................................................................... 5. Turn Your Phone On and Off .
Nov 05, 2015 | Kyocera Cell Phones
Blutooth codes for kyocera
Step 1 Charge the Bluetooth headset battery. The headset is fully charged when the indicator light turns off. Step 2 Unplug the charger and check the indicator light to ensure that the headset is turned off. If the indicator light is on, the headset is on. Turn off the headset by holding the multifunction button (the button in the middle of the headset) until the indicator light blinks red and shuts off. Step 3 Press and hold the multifunction button until the indicator light blinks red and blue to place the headset in pairing mode. Step 4 Turn on Bluetooth on your phone to start searching for available devices. When the search is complete, a list of available devices appears on the screen. On many phones, the Bluetooth options may be found in Settings. Step 5 Select the Kyocera Bluetooth headset name from the list. The phone prompts you to enter a passcode. Step 6 Enter "0000" using the phone's keypad to finish connecting the headset to your phone.
Aug 11, 2014 | Kyocera Cell Phones
Cell Phones Logo
Top Kyocera Cell Phones Experts
Mufaddal  Kurlawala
Mufaddal Kurlawala
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
