Question about ASUS Computers & Internet
How do i remove the ram from asus zenbook - ASUS Computers & Internet
    Sergeant:
  • 250 Answers
It it is located at the bottom of the device.. Flip over your Zenbook carefully, and on the bottom side there will be one or two small flap doors with a screw in it the memory is under one and the HDD Drive is under the other.. Be sure to shut down and take battery out before you change or take out memory or HDD Drive.. Hope this helps.. Ian.C
Posted on Jun 13, 2019
2 Suggested Answers
SOURCE:
Geekman
  • 32281 Answers
SOURCE: asus zenbook wouldn't start
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Nov 17, 2012
Zenbook asus very slow
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program.
To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends.
After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
Dec 02, 2013 | ASUS Zenbook Ux31e-dh72 Core...
Wifi/ bluetooth card failing
The wifi card is particular to your machine. Use a wired connection. You should be able to achieve 100Mb with a lan cable
Nov 19, 2013 | ASUS Zenbook UX31E-DH72-RG 13.3" Ultra...
I forgot my bios password ,How to get rid of the bios password on ASUS Zenbook UX32
remove the cmos battery switch on the machine and switch off then put back the cmos battery and switch on and all will be well
Sep 29, 2013 | ASUS Computers & Internet
Asus zenbook ux32a intermittently goes blank
Sounds like mine, it does that when it over heats. A lot of video activity speeds up the process.
Sep 12, 2013 | ASUS Computer International Asus ZENBOOK...
Asus ultrabook has black screen
restart and HOLD the keys CTRL or FN+f11 or f12 depend of you marks, and go to restore factory default and ready
However if the problem persist, take out the small battery lithium inside from +3vdc and mesure with VOM, if the voltage is lower from the 3 replace it, and clean the contacts. This battery hold the information in memory RAM. try again.
If the problem persist, you have problem with control board video/lcd, go to the repair shop for fix it.
God bless you
Jul 13, 2013 | ASUS Zenbook Ux31e-dh72 Core...
Flickering lcd screen on asus laptop
ur laptop fall ? check the conector , if not solve the problem just go for warranty , i see few ips panels dying or asus motherboards
Jan 26, 2013 | ASUS Zenbook Ux31e-dh72 Core...
I only get a wifi connection when I am next to the wifi hub. I lose the signal when I move 4 meters from the hub. Other laptops pick up the wifi without problem. I have tried using the zenbook on main
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
Jan 08, 2013 | ASUS Computers & Internet
Asus zenbook wouldn't start
Nov 17, 2012 | ASUS Computers & Internet
Open Questions:
Computers & Internet Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
