Question about HP Office Equipment & Supplies
HP Laserjet M1522nf when switched on printer initializes but no display on printer panel and at other times printer is switched on and panel displays printer initializing.
SOURCE:
  • 300 Answers
SOURCE: No display and no light indicators when powered on
If the printer control panel is blank when you turn on the printer, check the following items.
1. Make sure that the printer is plugged into an active electrical outlet that delivers the correct
voltage.
2. Make sure that the on/off switch is in the on position.
3. Make sure that the fan runs briefly, which indicates that the power supply is operational.
4. Make sure that the control panel display wire-harness is connected.
The control-panel wire-harness connector can easily be disconnected when you install the top
cover. If the control panel does not work after the top cover is installed, verify that the wire-harness
connector is fully seated into its DC controller PCA connector.
5. Make sure that the firmware DIMM and the formatter are seated and operating properly.
6. Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again.
If the printer control-panel display is blank, but the main cooling fan runs briefly after the printer
power is turned on, try printing an engine test page to determine whether the problem is with the
control-panel display, formatter, or other printer components.
Engine test page
To verify that the printer engine (all printer components except the formatter, formatter DIMMs,
EIO products, and the stacker or stapler/stacker) is functioning, print an engine test page. Use a
small, non-metallic, pointed object to depress the test-page switch, which is located on the right
side of the printer
The test page should have a series of vertical lines. The test page will print from the last tray you
printed from. However, if the printer has been turned off and then back on since the most recent
print job, the page will print from tray 2. The printer will continuously print test pages as long as
the test-page switch is depressed. The printer will not print a test page if it is in PowerSave
mode.
A damaged formatter might interfere with the engine test. If the engine test page does not print,
try removing the formatter and performing the engine test again. If the engine test is then
successful, the problem is almost certainly with the control panel, or the cable that
connects it.
Hope this helps
Posted on May 24, 2008
  • 81 Answers
SOURCE: Printer does'nt initialize
This could be a Jetdirect network card fault. Remove the card and power the printer on. If it powers up and goes ready then power it off again, refit the card and try again.Sometime reseating the jetdirect card will sort this problem If it doesn't work, then i recommend replacing the jetdirect netwok card.
Posted on Oct 13, 2009
  • 31 Answers
SOURCE: How do I scan a document on a HP Laserjet m1522nf...
install full software, download from www.hp.com
Posted on Aug 10, 2010
seeker5211
  • 1089 Answers
SOURCE: Model HP LaserJet M4345 MFP The printer displays
You've done everything but replace the formatter.
Can you look at the Event Log? Look for a 79.xxxx error. That is definately a formatter.
Is this a solid error, meaning does it appear when printer inits?
Remove the DIMMs and flash memory and network cable. And reinstall one by one until error reappears.
Do you have another 4345 that you can "borrow" a formatter from?
Posted on Jan 12, 2011
vinay229229
  • 1121 Answers
SOURCE: My Hp Designjet T1120 fails
Reset the formatter & check,,
Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part.. 11_19_2011_3_40_14_pm.jpg
Posted on Nov 30, 2011
HP Laserjet M1522nf display not working
if it is frozen on boot, you need to replace formatter or warm its chip until 280°C for 20-30 seconds.
Feb 27, 2015 | HP LaserJet M1522nf Multifunction Printer...
My printer is HP laser jet M1522nf series. It rotates inside while switching on but no display comes.
Formatter faulty,
Symptoms: No display, not recognized by system,if network cable connected to the port data transferring LED are wont glow or low brightness,
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
My hp laserjet M1522nf is showing Firmware corrupt ready 2 download
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
Feb 22, 2011 | HP LaserJet M1522nf Multifunction Printer...
The printer displays the hawlett packard message and won't print
This sounds like a main Formatter board Problem.
For a possible solution follow the posted link below.
The printer is attempting to initialize itself and cannot.
M1522INFORMATION
Dec 06, 2010 | HP LaserJet M1522nf Multifunction Printer...
Why does my HP laserJet M1522nf say private? how can i change the settings to auto?
Try an nvram. Hold the down arrow and the cancel button. Turn the printer back on and wait until permanent storage init is displayed.
Al
Aug 31, 2010 | HP LaserJet M1522nf Multifunction Printer...
Printer continous initialise no error coming & 5 arrows appear on display panel
You have to be a little bit more specific next time, we have 2 possible scenarios:
A) The printer freezes while initializing with some arrows
B) Blank display / No display
Both are usualy caused by a problem in the formatter (Mainboard) . There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP (1 800 334 51 44 begin_of_the_skype_highlighting 1 800 334 51 44 end_of_the_skype_highlighting) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
I can tell for sure that the warranty for this specific model M1522NF will be extended 1 extra year (means you have 2 years coverage) if the printer has one of the issues listed above I Hope this can help You can contact me directly on : eliteprintersolutions@hp.com
Jul 21, 2010 | HP LaserJet M1522nf Multifunction Printer...
How to Reset HP Laserjet M1522nf security password
Hi the easiest way is a nv ram
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Good Luck
Al,
Eliteprintersolutions@gmail.com
Jun 16, 2010 | HP LaserJet M1522nf Multifunction Printer...
Display reads "card slot not initialized"
Turn the printer on.
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
Open Questions:
Clive
Clive
Ekse
Thomas F. Schneider
