STATUS model rct-08 remote control. One by one the buttons have failed so that now I only have one working button. Where can I get a replacement remote control as the sockets are all still working?
2 Suggested Answers
SOURCE:
SOURCE: i need a user manual for a STATUS model rct-08 remote control as it needs resetting.
Plug the receiver into a mins power socket. The red LED flashes every second.Press any on switch for more than 2 seconds on the remote control. The receiver will learn the code. When the LED flashes continuously after 2 seconds and goes off it means the receiver has learnt the code. You can add various receiver sockets to any one on switch to create a zone. Repeat these last 2 steps for all receiver sockets selecting a different receiver button for each receiver socket. After a power cut pull out the receivers from the mains power socket and repeat the above steps.
Plug the device you want to operate into a receiver socket. Press the on or off button to activate the receiver socket. Or press the on/off button directly on the receiver socket to operate the plug.
To decode. Press the On/Off button on the receiver socket for more than 3 seconds. After 3 seconds the LED flashes once per second, decoding is successful.
Press the All/Off switch on the remote control for more than 3 seconds. After 3 seconds the LED flashes once per second, decoding is successful.
Hope this is OK for you. Peter
Posted on Dec 06, 2011
Convert daewoo dvd-vcr mod df-4501pn to region free
I did not find any hack for your model, I don't think there is any I will just doublecheck.
Jul 20, 2008 | Televison & Video
Sim number for Pontiac torrent remote?
2007-2009 Pontiac Torrent Keyless Entry Remote Key Fob ...
www.amazon.com/...Pontiac-Torrent.../B009E9LX5O
Amazon.com, Inc.
Rating: 5 - ‎4 reviews
Amazon.com: 2007-2009 Pontiac Torrent Keyless Entry Remote Key Fob With Free ... Manufacturer Part Number, Part #: 15913420, 20869056, 20952475 ...Missing: sim
2008 08 Pontiac Torrent Keyless Entry Remote - 4 Button ...
www.amazon.com/Pontiac-Torrent...Remote/.../B0068...
Amazon.com, Inc.
Amazon.com: 2008 08 Pontiac Torrent Keyless Entry Remote - 4 Button Models with ... GM Part Numbers: 20868672, 20952474, 15913421 w/ Remote Starter ...Missing: sim
2007 to 2009 Pontiac Torrent Factory Remote Transmitter ...
? 3:28
https://www.youtube.com/watch?v=OASrgxUXXdI
Nov 7, 2012 - Uploaded by Lessco Electronics
2007 to 2009 Pontiac Torrent Factory Remote Transmitter ... Press the set/reset button until REMOTE KEY ...Missing: sim
Jan 31, 2016 | Televison & Video
What is the code to make LG DP522H DVD player region free (0)/ multi-region? (this replaces my question yesterday where I got the LG model wrong!)
Ok so here is how it was done.
Press the Pause button on your remote control. Using your remote control enter the code 3, 1, 4, 1, 5 and 9, Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player
Or
Press the Setup button on your remote control then, Step, Next, Up and Down, select the region of your choice or Bypass for region free, save and then Exit the menu.
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P, LG 4950S, LG 5083, LG 5822N, LG 593W
Aug 12, 2012 | LG Televison & Video
I need a user manual for a STATUS model rct-08 remote control as it needs resetting.
Nov 21, 2011 | Televison & Video
My remote will not turn the tv on it work for about a week. I have replaced the batteries numerous times with no help
Can another remote turn on and off the TV? Do the buttons on the TV itself work (assuming a front panel lock isn't engaged)? Is this the original remote for the TV or a universal remote?
The possibilities: 1) The remote has failed. If you have a digital camera, take a picture of the IR side of the remote when someone presses the buttons. When you review the picture, you should see a bright spot in the picture. This indicates the remote is at least sending a signal. Sometimes the buttons will fail to make contact with the circuitry of the remote (due to wear). Other times the IR transmitter fails (the suspect if there is no light in the pictures from multiple button presses of the less used buttons). It's cheaper to replace the remote than it is to repair it.
2) The remote has lost the code for the TV. If you have a universal remote, try reprogramming it. (Cable or Satellite controllers count in this group).
3) The IR receiver on the TV has failed (if the buttons on the TV work) or the entire board has failed. You can get replacements for these at some sites. Try shopjimmy.com (minimally used parts) or partstore.com. You will need to open the TV and get the part number for your individual model for best results.
4) The TV won't turn on due to power supply problems.
If you need a replacement remote, a universal remote should work but the low end ones may not access all of the features of the original. Check for buttons that match features like Menu and Source (Input) if your TV doesn't have equivalent buttons on the TV itself. The remotes that are programmed via a USB connection with a computer are the easiest universal remotes to set up. If you want the original remote (or a close substitute that will perform all of the original features), first check if a parts store exists for your TV manufacturer (Samsung for example). Next try remotes.com and search for the TV model (leave out the manufacturer).
I hope this helps.
Apr 19, 2011 | Televison & Video
Sanyo remote control will not aiiow the sanyo tv to go on or off.
Is this the original remote or another remote? There are a few things to check. First try new batteries in the remote. (If it is not the original remote, check that the code hasn't been changed.) Next do the buttons on the TV itself work?
If the TV responds to the buttons on the unit, then use a digital camera to take a picture of the remote (the IR beam side) when someone presses a button. Looking at the picture you should see light from the remote. If you do not see any light, then replace the remote.
If the remote is sending a signal, then the receiver has failed. You may be able to replace this at partstore.com or shopjimmy.com. First try searching on the model. If that fails, open the tv and record the part number. Search for the part itself (since many parts are used for more than one model, it may be listed for another brand).
If the buttons on the tv do not work, then the entire board probably has failed. Again try to find the part.
I hope this helps.
Mar 17, 2011 | Sanyo Televison & Video
I need to set up my UPM RCT 100/TR430 remote light control and don't have the instructions. Can you help?
Press the learn button on the part that plugs in. Then press the "on" button for the remote and it should learn the code.
May 13, 2010 | UPM Remote Control Timer Set
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Ekse
