Question about Canon Office Equipment & Supplies
I want to change the paper in canon image runner 2202 from A3 to A4R
SOURCE:
iservice
  • 318 Answers
SOURCE: How do you change the paper size on a canon ir3025
Open the drawer,detach the blue paperstop by pushing it left and downwards.Insert the stop again at the A4R holes.Unlock the top and front vertical lock and slide it to the A4R possition.Set the blue dail to A4R so that the machine knows wat tipe of paper is loaded.
Posted on Aug 18, 2009
Testimonial: "Thanks so much for this - worked perfectly"
  • 990 Answers
SOURCE: remove a paper jam under the fuser unit on a canon
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
  • 1316 Answers
SOURCE: code de panne E000584-0003 for canon image runner
Please check the main thermistor TH1 has poor contact or open circuit.,the thermal switch is opened.In this case the fixing heater has opened and the SSR is faulty.
For the reset : COPIER-FUNCTION-CLEAR-ERR.
Posted on Sep 01, 2009
iservice
  • 318 Answers
SOURCE: I have a Canon Image runner 1023. when I print i
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Posted on Dec 09, 2009
canontech
  • 1219 Answers
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Posted on Jul 25, 2010
Testimonial: "so thanks"
Error Code E019-0002 for canon 2202 please help me
There's a good discussion about what to do for that particular fault code in Canon Image Runner laser printers in this link.
Canon iR1020 E019 0002 Error Code
Nov 20, 2016 | Canon Office Equipment & Supplies
Canon image Runner 2202 error code E000-0000
Aynalem, Canon image Runner 2202 error code E000-0000
Aug 10, 2016 | Canon Office Equipment & Supplies
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
Canon ir 2202 error code e0141-0000
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR2200
Jun 19, 2015 | Canon Image Runner 2022 Copier
I need to copy from A3 to A4R and cannot find how to change the paper to A4R
Right click on printer. Click on Printing preferences. Under quick setup tab, on the printer paper size box click the drop down arrow, choose A4.
May 16, 2011 | Computers & Internet
How do you change the paper size on a canon ir3025 photocopier from A4R to A4
Aug 17, 2009 | Office Equipment & Supplies
How do I change the paper size of the paper source in canon image runner 5570
Just enter the paper stock that you want to use and adjust the guides. The machine should pick up the size if it's in universal cassettes. If it's the bypass, you select 'paper select' then select the bypass and choose the size that you want.
Jul 31, 2008 | Canon Image Runner 3320I Copier
20 people viewed this question
Clive
Clive
old marine
old marine
