Hi, have data on a DiamondMax Plus8 that would like to access. IS there a USB adapter cable I can use? Many TIA. Bren
    Habit-Forming:
  • 170 Answers
There are adapters for almost anything and everything these days, and yes there are several USB adapters and several places to access the them. For online purchase "Amazon, and Ebay" would have them. Computer stores like "Fry's Electronics, Staples, Office Max, {etc} would carry them and there pretty cheap as well. That would be the SATA to USB adapter or the old Ribbon to USB adapter. In the future I would recommend purchasing and External Hard Drive and that comes with the attachments plus it's portable and they now have Storage into the Terabytes now so they have plenty of space and also if you lose data from a Hard Drive don't panic they have a program that's called HDD Data Recovery for lost data and even lost pics that were once on that Hard Drive.
Hope this helps.. Ian..
Posted on Jun 13, 2019
SOURCE:
SOURCE: motorola L6i usb data cable software
my motorola l6i cannot connect with my pc through data cable. so pls give me USB Data transfer sotware .................send software on my e-mail id....................www.raj_veer.19@rediffmail.com
Posted on Sep 30, 2008
SOURCE: i want sigmatel s90 usb data cable drivers
hi, i m pradip
Posted on Apr 24, 2009
  • 41 Answers
SOURCE: SGH-E250 internet access via data cable or blue tooth to PC
You have to buy a data cable or use bluetooth.Create a dialer which dials *99# using your samsung modem over bluetooth
Posted on Jun 03, 2009
  • 150 Answers
SOURCE: Can PC hard drive cable be converted to a USB cable?
Try USB2 to ISDE & SATA cable adapter
OR
why not put that 1 st drive into the other computer if compatible.. BIOS should auto detect if it's connected to 2ndry chanel
Posted on Oct 27, 2009
  • 16 Answers
SOURCE: usb cable
What is your cable connected to? Your drive may be mapped to a letter that is already being used, which hides it.
Right click My Computer, Select Manage
Highlight Disk Management
Find the device that your cable is connecting
Right click that device
Select change drive letter and path
Choose a drive letter that is not in use.
Posted on Feb 04, 2010
My Maxtor DiamondMax Plus 9 80GB ATA/133 HDD with a X-Media USB2.0 TO IDE & SATA cable adapter
Check (under high light) flat IDE cable pins on the mini-board. Many pins, and many chance to loose contact.
Feb 10, 2014 | Computers & Internet
Trying to transfer data from an old harddrive i have (maxtor, diamondmax plus 9 80 GB ATA / 133 HDD) to My HP laptop
Install the hard drive into an USB hard drive adapter case the plug this USB hard drive into the USB port in your laptop. The laptop will see it as an external storage device, open the various folders and copy the files to your laptop.
You can delete any unwanted files off this external USB hard disk and use it for backups and file transfer.
Mar 14, 2013 | Computers & Internet
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
Cannot access. it clicks
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Feb 03, 2011 | Cavalry Storage (CACF37250) 250 GB USB 2.0...
Hi my WD 1T is locked and formated ! Any recovery information I had not returned Information are very important in my HDD Please help me to be able to get my lost data recover thanks
* the USB cable
* the power-adapter
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Dec 10, 2010 | Computers & Internet
Hi, We just disconnected an old LG Hard Drive and hooked up a brand new one. When we attempted to reconnect the old hard drive for the purpose of transferring data/pictures to a flash drive, we couldn't...
* the USB cable
* the power-adapter
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 13, 2010 | Computers & Internet
Hi, where can i get an alternative power supply other than usb to charge it? regards pete
You can use any usb adapter with a jack suiting your device (commonly mini USB) and equal or higher power than the one mentioned on the device. Voltage for usb is 5.0 volts, still check what the device says. I have never seen a usb adapter on different voltage tho.
I had to buy a spare adapter for my Qtek 9000, chose Spyke, model PST-2005U. It gives a whole 2.0A, can charge up to four standard devices (0.5A each as per usb port standard). It has also easy to notice LED, data input, so that you can access the device even when charging, and a replaceable cable on a USB plug, so that you need just one cable to charge your device and connect it to PC.
Here it is: http://www.maxtronix.biz/product/2008-4-26/2008426122753.html
It has several options, so be careful.
Nov 12, 2009 | Audio Players & Recorders
OR
Oct 27, 2009 | Gateway Computers & Internet
WANT USB DRIVER
Go to www.nokia.com
There, search for ur phone.
Download PCSuite.
Install it and connect the phone.
Now you can connect ur phone and access data in it.
Feb 01, 2008 | Adapters.com BT-0333 Bluetooth USB Adapter...
Computers & Internet Logo
18 people viewed this question
Alun Cox
