Question about Kodak EasyShare Z612 Digital Camera
When trying to upload my pics, computer says can't locate device
My camera is a kodak easy share Z612. Was working fine until a couple of weeks ago. Have uoloaded hundreds of pics now want let me keep getting the same error. I have the disk and have reloaded it still want work.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 18, 2012
SOURCE:
  • 48 Answers
SOURCE: kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Posted on Nov 16, 2007
  • 30 Answers
SOURCE: no install disc
Go to Kodak.com and download an install disk for your camera model. It is free.
Posted on May 09, 2009
Josue Pongco
  • 154 Answers
SOURCE: when i upload photos to kodak easy share...it
Rebuilding the catalog might solve your issues.
If your on Windows XP
Shut down Kodak Easyshare SW, also shut it down from the system tray near the clock.
Go to C: then Program, Kodak, Kodak Easyshare Software, the Bin Folder, rename the catalog folder and change it to OldCatalog.
Then on same window click on search on the top of your screen and type on the search box ESBK, once you found it, delete the two icons that says ESBK.mb and ESBK.mbb.
Then relaunch the easyshare software then try to transfer again those pictures.
Hope this would help.
Posted on Aug 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: HOW TO UPLOAD VIDEOS FROM THE CAMERA
First install software and drivers, then run easyshare program, then turn on camera, then lastly hook up with usb cord.
Posted on Oct 01, 2009
  • 102366 Answers
SOURCE: how do i format a kodak memory card 4 gb sdhc for
Unfortunately. you don't. The Z612 works with SD cards, not SDHC cards. You're limited to cards 2GB and smaller.
Posted on Jun 14, 2010
I have a kodak easy share camera M340 and I can't take any photos since it says Internal memory is full. Help
Buy yourself an SD memory card and transfer your pics to the card. That will clear your internal memory. You can save all your pics that you take from now on in the SD card.
Sep 10, 2011 | Kodak EasyShare Z612 Digital Camera
How do you erase the internal memory on a kodak easy share Z612
Press the Review button. Press the Delete button. Follow the screen prompts. "ALL" deletes all images from the current storage location.
Jul 11, 2010 | Kodak EasyShare Z612 Digital Camera
How do i format a kodak memory card 4 gb sdhc for my kodak easy share z612
Jun 14, 2010 | Kodak EasyShare Z612 Digital Camera
MY COMPUTER CRASHES EVERY TIME I TRY TO UPLOAD PICS AND THEY WANT UPLOAD HELP THIS HAS SHORT VIDEO CLIPS AS WELL IT WILL GO THROUGH THE PROCESS OF SEEING IF THERE ARE DUPLICATES AND AFTER THAT IT ACTS LIKE...
Please reinstall your version of Easy Share software:
Please follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Jan 12, 2010 | Kodak Easyshare C813 Digital Camera
Horizontal lines running through pictures.....Z612.
I've had sinilar problems with mine. I bought it in November of 2006 and sent it back to Kodak (under warranty) 3x before they finally agreed to replace it (with a refurbed unit). Well, that was in June of 2007 and the problem is now baaaack with the reoplacement camera (same model)... I'm requesting Kodak replace it with another model, but I'm "out of warranty" and they want me to pay them $145 to repair (which they've never been able to fix for me). So I am requesting them to replace with a different model.
May 15, 2008 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Error #803
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Apr 10, 2008 | Kodak EasyShare Z612 Digital Camera
Kodak easy share z612 will not turn on to take a picture
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
52 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
