Question about Samsung Digimax S700 Digital Camera
Samsung Digimax S700 is frozen with lens open
Camera is frozen with lens open - new batteries - turns on, then off
can you help?
  • 6 more comments
  • JuanBKNY Dec 16, 2007
    Same problem...camera turns on then off, lens is stuck in open position.
  • Anonymous Dec 20, 2007
    my samsung s700 lens will not open all the way when camera turned on. seems to be skipping a gear or partially broken gear drive. need to know how to take the lens apart for possible easy fix. maybe exploded view of camera. or maintenance manual. need to take it apart for fix.
  • askforadvice Dec 29, 2007
    I have the same problem, The lens is frozen with full new batteries; I push the power butten, there is a green light but the lense refuses to react, after a few trial, the green light is off as well. Completely frozen.
  • Cuto Mar 25, 2008
    my camera's lense is frozen and doesnt turn on not even with full batteries
  • reverendmoss Aug 17, 2008
    same issue. camera is frozen in the off position with the lens open, regardless of battery type or power. the light blinks while the power or play button is held, but then it makes a light click sound and switches off.
  • dougquaid Sep 27, 2008
    same problem, but it only started doing this a few months ago, now the lens is completely frozen all the time. I also think it may be a gear problem inside the lens mechanism, but dont know why this would happen after a year or two usage, and how to fix it
  • Anonymous Dec 25, 2008
    I have the s700 and loved it, but it had the same problem, I sent it away to be fixed and $100 later it is still not fixed!I am done with Samsung!!!1
  • spoiltrotten Jan 08, 2009
    samsung camera not turning on! I have this problem with my stupid camera too!!
    The lens is stuck out and I can't do anything with it. I try turn it on but the light justs flashes and the camera makes a clicking noise.
    Any way of fixing this? I can't do what mark sox says because I can't even turn it on.
  • 24 Answers
The beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Posted on Jan 13, 2008
Yea,mines definitly has a gear drive problem with the lens. it try,s to extend all the way but seems to be skipping gears then i have to pull it out by hand. need to know how to take the lens apart to fix it. any camera tech,s out there. amt51
Posted on Dec 30, 2007
I had this same problem, and all i did was pop out the SD card, and tried turning it on without it in there.  It powered up just fine.  I then replaced the SD card and all was well.  Possibly a problem with teh SD card.
Posted on Dec 27, 2007
6ya staff
SOURCE:
My samsung s700 camera wont turn on its beep three times but wont turn on
try charging the battery or using a new battery. if that doesnt work you should probably send it in to be looked at.
May 04, 2011 | Samsung Digimax S700 Digital Camera
Samsung digimax s700 gives 3 beeps and turns off
The Samsung digimax takes standard AA batteries (but you already new that). The beeps sound like a flat battery warning.
A lot of reviews of this camera note its very high drain on batteries. Are you using good quality AA batteries (for example Duracell M3 or Energizer lithiums)?
If you are trying to run it with "very inexpensive" alkalines (or worse yet - common zincs), then you may proceed directly to flat battery warning, as they cannot provide enough sustained current to run it.
Feb 28, 2010 | Samsung Digimax S700 Digital Camera
Samsung digimax S700 battery problem
Clean the battery terminals and clean the metal contacts in your camera and insert your battery and check, whether you get low battery warning.
Hope this helps.
Jan 31, 2010 | Samsung Digimax S700 Digital Camera
Lens and camera are frozen or stuck
if the lens is stuck out , twist the lens to the left with your hand and it should go back in. thats what happen to mine and i fix it . hope this helps you.
Apr 10, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Samsung s700 camera lens won't retract
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 15, 2008 | Samsung Digimax S700 Digital Camera
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Samsung Digimax A400 Digital Camera
OUTER LENS POPPED OUT
Since you are out of warranty you have to repair it yourself or get a new one. If you can open it and take it all apart it's pretty simple just remember how things look on the inside. All lenses that retract are on a little motor and gears. This is what you have to check and unfortunately it's usually under everything else. If you can get there see if the gear housing is cracked, the gears are in place and not striped and meshing ok. I believe it is going to be the gears. It's not as hard to take a part as people make it seem.
May 27, 2008 | Samsung Digimax S700 Digital Camera
Pictures either very white/red for Samsung Digimax S700 digital Camera
The iris in the center of the lens may be stuck open or damaged.
you can look inside the front a focus/zoom/ turn on off and see if it opens and closes.
Jan 27, 2008 | Samsung Digimax S700 Digital Camera
Help with frozen lense
-turn the camera on
-select Set up 2
-click OK button
Dec 29, 2007 | Samsung Digimax S700 Digital Camera
Whoops, It's an S700
Send it back they did not fix it prperly- did they.
Sep 04, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S700 Digital Camera Logo
703 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
