Question about Sony Televison & Video
When I connect my oider v ersion of Mi Box to my older Sony Bravia it says no signal..it worked fine before I moved..I have Android tv hooked up..Chromecast and Firestick...is Firestick stopping me
SOURCE:
  • 27 Answers
SOURCE: Sony Bravia and Comcast MY DVR Not Working Now
Greetings...
Is the Comcast box digital? and is it a Scientific America 8000 series box?
If so, try unplugging the power to the cable box for a minute, replug and after the reboot see if that fixes the problem...
Ed
Posted on Apr 03, 2008
  • 125 Answers
SOURCE: no signal sony bravia to dell laptop
Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
Posted on Mar 20, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Posted on Mar 21, 2010
Sony Bravia TV
If you get a blue screen at turn on and a short time later it shuts off--power supply is ok--set is shutting down as no signal detected to protect the screen.
If using a box first unplug it and wait and plug back--let box try to reboot itself.
Also as a test hook a DVD etc to a rear set of audio/video inputs and go to that input quickly when the set comes on (have DVD connected and on---see if set works that way.
No signal either a problem with the set or the signal source (box?).
Mar 31, 2012 | Televison & Video
How to fix out of range problem on sony bravia with pc
Well I just changed the resolution settings in my android box to 720 from 1080p > plugged it in and my box now works...simples.
Jan 29, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Hi, I have a sony bravia tv ( klv20G300A) which was bought in Hong Kong about3 years ago . I haven't been able to get it to work with the uk digital signal. I am wondering about it's compatibility-...
This tv has analog tuner and you need digital tuner in tv to get digital signal in UK, alternate way is to hook cable box with this tv that will convert digital signal into AV output that will connect to AV input of tv to get cable channels.
Aug 03, 2011 | Sony BRAVIA KLV20G300 20 in. EDTV-Ready...
TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
Nov 28, 2009 | Sony Televison & Video
I have connected my Charter HDTV settop box to the strdh700 in the 'sat in' hdmi connection, then connected the 'out' hdmi to my sony bravia tv and the signal isn't getting there. any suggestions?
If you're not getting the audio signal, please select the Audio for HDMI to TV+AMP in Menu display. If you're not getting the videos, please check if the TV is HD ready and supports 1080p signals. Also check if the connections are firm and secure and you selected the correct input on both Receiver and TV. Please try connect the Settop box to different HDMI port of the receiver and try. You can also try connecting the Set top box to tv directly and check if its working. If its working fine directly with the TV, you may try to replace the cable and try else the receiver may require service
Sep 22, 2009 | Sony STR-DH700 A/V Receiver
Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
May 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No picture
Try to connect a DVD player or some other device to get video into the TV, just to make sure is not your digital box.
Try all the video inputs if possible.
Mar 08, 2008 | Sony BRAVIA KDL-40V3000 Television
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
