Question about Xerox Office Equipment & Supplies
HFSI counter what is 954-842 and what are the default value of Xerox WC 7435
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
You just must to reset the HFSI valors to 0.
Posted on Sep 11, 2019
5 Suggested Answers
SOURCE:
  • 24 Answers
SOURCE: Need to enter service mode on a Xerox 7435
The service tech should do this. The 7435 should be less than 3 months old, and Xerox should fix it. If you bought it from Global, or another company that does not actually employ Xerox technicians, try appealing to them, but I cannot tell you for sure what the outcome will be. Buying from an authorized agency ensures that you can use your "Total Satisfaction Guarantee".
Posted on Jun 10, 2009
SOURCE: wath is default username and
Email id username deffrent
Posted on Feb 07, 2011
  • 132 Answers
SOURCE: Xerox 7435 error code 010-328 whtes the problem
it is the code for fuser heat control problem. Usually, the unit has its airflow restricted try moving the unit or cleaning it to see if the problem clears
Here is a list of all the error codes
WorkCentre 7425 style Fault Code List Part
Posted on Aug 02, 2016
tonythetumbl
  • 323 Answers
SOURCE: Wc 7435 error code 062-371
Xerox say the code is a scanner lamp failure.
They also suggest you switch it off AND unplug it for at least 45 minutes.
When you turn it back on, it MAY reset & be fine.
If it doesn't, you'll need an engineer to replace the part as they say it's not a user-serviceable replacement.
Best of luck.
Posted on Mar 09, 2018
What is the error reset code for xerox workcentre 7345 fuser unit. please help
Press and hold the 0 key for 5 seconds and then while still holding, press the Start button. Enter password 6789 then press confirm.
Select Adjustments/Others, then initialize HFSI Counter then enter code 954-804, then select reset current value.
Apr 19, 2016 | Xerox Office Equipment & Supplies
Reset xerox c2255 btr (r7) counter
Code is 954-821
To enter diags and reset hold down right arror then left arrow, release both together the press online within 3 secs.
goto preventative, then HFSI. dont change anything else in this area as you can toast the machine.
Feb 11, 2015 | Xerox Office Equipment & Supplies
How do I solve wc 7435 error 010-338?
Hi
I found information about this error and some approaches to solving it here:
http://www.support.xerox.com/support/workcentre-7425-7428-7435/support/enus.html
and they can be tried in the order given. Hopefully either 1 or 2 or 3 on the list will work as they are non-cost options as opposed to number 4 which could be quite pricey.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Xerox WorkCentre 7425 7428 7435 Second...
Xerox 7435, got from company who pulled out the hard drive, so I am missing hard drive and the OS, how can I get in going?What type of hardrive do I need?
Hi Arthur
Look at the cable that would connect to the hard drive.
The Data side is either SCSI, or ATA or SATA.
Look these up on Google and see what matches.
All modern Hard Drives are 3.5" for desktop computers or 2.5" for laptops. Visit a site such as OWC (Other World Computing) to purchase a drive.
Only Xerox would have the OS unless you know where there is an old copy.
Check out
https://www.google.com.au/?gws_rd=ssl#q=xerox+7435+specs
Sep 09, 2014 | Xerox Workcentre 7435 Color Multifunction...
How do i reset r6,r7,r8 on xerox 7435
R6-7: Go to consumable tab on your printer.
Select the R6 or R7, select reset counter.
R8: You're not able to reset it
Mar 12, 2013 | Cameras
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
Hi, In my printer Xerox 7245 display it appears Replace Transfer belt error. So please guide me how to reset value without replacing ETB
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
Jun 04, 2009 | Xerox WorkCentre M-24 Color Copier
43 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
