Question about Option Computers & Internet
Mine has a same issue Bluetooth won’t sync and usb isn’t being recognized , if you tap on the usb option it’s like it isn’t even there
  • Option Master
  • 5,030 Answers
No PC stated (you are posted to computers and not CELL phones)
NO OS stated at all windows/ y/n if yes, which one W10?
NO DEVICE STATED, USB. (vast and endless this)
are you sure BT works on this unstated PC.?
most old PCs it was an option on laptops. very common..
IF BT works on other devices say so and do so. first.
or run HWinfo32.exe portable and free to see if the BT port option is even there at all. inside unstated PC.
Posted on Jun 26, 2019
2 Suggested Answers
SOURCE:
SOURCE: camera wont sync with any computers
check your data cable. Maybe you have troubled with your data cable. Cable track is not connected from begin to the end. If you don't have a problem with your data cable, check the condition of the slot connector on the camera. Perhaps, the connection between usb connector is not the right track.
Posted on Oct 25, 2009
How do i connect my wireless keyboard?
Wireless keyboards need a USB or Bluetooth connection depending on witch for USB plug in the USB dongle and tap the sync button but for Bluetooth ur internal or USB Bluetooth dongle must be in pairing mode and the wireless keyboard in pairing mode as well
Jun 04, 2012 | Toshiba DX735-D3302 All-In-One Desktop
Iphone not recognized when attached with usb connnection
Try using different usb ports on your computer. If it doesn't work then try hooking up your iphone to another computer. If it still isn't being recognized then try a different IPHONE USB cable.
If your Iphone still can't be recognized after all of this then read the article at the link below.
http://support.apple.com/kb/TS1538
Also try restoring your iphone to factory defaults if necessary. This is a last resort. If your iphone still won't get recognized by the computer then it could be the connection on the Iphone is defective and in that case replacing the phone is the only option.
Nov 03, 2011 | Sony VAIO VGN-N325E Notebook
Cannot sync with my computer to my wildfire s mobile
hello Jb,
Setting up HTC Sync to recognize HTC Wildfire S
Connect HTC Wildfire S to your computer using the USB cable that came in the box. When
HTC Wildfire S prompts you to choose a type of USB connection, tap HTC Sync, and then tap
Done.
Wait for HTC Sync to recognize HTC Wildfire S
.On the Device setup screen, enter a
name for HTC Wildfire S.
Click Save. The Device panel then opens.
Aug 17, 2011 | HTC Wildfire
How do I get my handheld palm Tungsten E2 to synchronize via my USB bluetooth 2.0 adapter to my new computer that has Windows7? Microsoft windows said that bluetooth would work with Windows7,64 Bit; but I...
a. Plug the USB sync cable into a
USB port on the back of your
computer
b. Plug the cable into your
handheld
[ & ] OPTIONAL Press the power button to turn on your handheld if it is not
already on.
Continue with the onscreen instructions. Synchronize your handheld with your
computer by pressing the sync button on the USB sync cable.
Dec 01, 2010 | Computers & Internet
Connect to internet?
This answer assumes that the reader is already using their SD slot and wish to use another way to connect to the internet. I'm going to show you how to connect a USB Bluetooth dongle using the Toshiba e350 USB host cable. After that you can choose to share a computer internet connection via ActiveSync/WMDC or use BT DUN and a wireless phone with existing internet plan.
Windows based PC software (only needed for ActiveSync based internet sharing):
ActiveSync or WMDC
Toshiba PC Bluetooth stack 7.10.04 (or latest version for your operating system, I'm using Windows 7)
PC Hardware:
Super Mini Bluetooth 2.0 Adapter Dongle (mine was VID 0A12 PID 0001 Broadcom BCM2045 "CSR" based)
WM2003 PPC software:
Zeno USB Host Drivers v6.0a
Toshiba PDA Bluetooth stack 4.01 (filename bltstk-401-en.zip)
WM2003 registry editor (TaskMgrv2.9_WM2003SE.zip is a free task manager and registry editor, very cool)
Opera Mobile 8.65 (optional)
WM2003 PPC Hardware:
Toshiba USB host cable
2 or 4Gig SD card (for e350)
I'm going to target a Windows 7 PC with USB Bluetooth adapter, Windows Mobile Device Cener (WMDC), and an already partnered and synced Toshiba e350/355. The reader should already have a 2Gig SD card in the e350; remember WM2003 doesn't support SDHC. Any software to be installed onto the device should be done through ActiveSync Add/Remove and should not be installed to the default internal memory, but instead to the SD card.
Let's start by loading the e350 software. Install the Zeno Host drivers, followed by the Toshiba 4.01 stack. There is a newer version of this stack but it didn't work for me, so find the older bltstk-401-en.zip. The registry editor is needed for ActiveSync internet connection sharing but optional for BlueTooth Dial-up Networking (BT DUN). I'd recommend installing Opera Mobile as well. Be sure to press the reset button on the back of the e350 when done. You may now connect the USB host cable with Bluetooth adapter.
On the Windows PC connect your Bluetooth adapter and install the Toshiba PC bluetooth stack. Power up the e350 and, after a short time, there should be a wireless icon in the lower right hand corner of the main window. Back to the Windows PC, double click the Bluetooth icon in the task tray and you should be prompted to create a new connection. After awhile it should recognize your Pocket PC. If at any time you are prompted to insert a password for secure connectivity, write down a number (preferably 8 or more digits) and type it in. It will probably ask on the Windows PC first but once you continue immediately check your e350 since it will now prompt for the same password. Once it has been entered in both devices they are now "paired".
Tap the wireless icon on Pocket PC then Bluetooth Settings. Tap the magnifying glass to search for connections, your PC should already be listed as a remote device. Tap and hold over the name of your PC in the upper portion of the window and select Update Service. At least one COM port should be listed in the lower window. Tap and hold over it's name, then tap connection registration.
On the Windows PC open WMDC and select Connection Settings. Change the "Allow connections to one of the following:" drop down to the COM port listed on your device and be sure it's checked. The other settings should be default.
On the Pocket PC tap ok to close Bluetooth settings then tap Start > Programs > Bluetooth Folder > Bluetooth Connection. This will initiate an ActiveSync session and, if everything has gone well, it should connect, perform a sync then immediately disconnect. I have a problem with the immediately disconnect part, that's where the registry editor comes in. Using your preferred registry editor locate the HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\Bluetooth\DeviceProperty\Mode\ActiveSync\AutoDisconnect key. It's default value shoule be 1 but we want to change it to 0 thereby preventing ActiveSync from disconnecting after it sucessfully syncs.
With that done you'll probably need to reset the e350 again. At this point, because ActiveSync is set to share the computer internet connection by default, the next time you connect you should have internet access. Open your preferred web browser and check. When you are done with the internet, tap Start > ActiveSync and the Stop button. In Windows 7 as long as I'm connected I can see the Pocket PC in Windows Explorer as if it were an external drive. This makes it very easy to copy files back and forth wirelessly. Initially I set up a bridged PAN connection but, to be honest, ActiveSync works much better all around.
For BT DUN you'll need a properly configured and enabled Cell Phone with bluetooth DUN capabilities. Simply make the phone "visible" and search for it as you did the Windows PC. Pair with the phone, Update Service and register Dial-Up Networking. Tap Start > Settings > Connections tab > Connections > Add a new modem connection (Tasks tab). Enter a name for the connection and choose Bluetooth Card as the modem, then set the dial-up number, User Name, and Password from your Cell Provider. On the Advanced tab (next to Tasks tab) you may want to tap Select Networks to verify "Programs that automatically connect to the Internet should connect using:" My ISP.
You can set up ActiveSync Internet sharing along side BT DUN. When ActiveSync is connected it will automatically be the source internet connection. When disconnected, the e350 will automatically attempt to use the BT DUN connection instead.
Why not use the default Microsoft BT stack on the PC? It doesn't publish any real services, just a COM port that I never got to work. The Toshiba BT stack does have a 30 day warning so you might need to fix that.
For me the total cost of setup was about $30. The host cable was $15, the SD card $10, and the USB BT dongles were $2 apiece.
Nov 03, 2009 | Toshiba e350 Pocket PC
Syncing blooetooth
Headsets don't be synchronised, as syncing means to update to devices with each other.
Bluetooth headsets are paired. Pairing means that both Bluetooth devices recognize each other and trust each other, so you do not need to provide any type of confirmation.
So, follow the phone's manual to see how to switch on the Bluetooth and make it visible. Now, there must be an option like make a new paired device. Consult your manual for this. The phone will search for a deivce and they will be paired.
You can even pair a PC and phone, phone and phone and every kind of Bluetooth enabled devices.
Jan 30, 2009 | Motorola Mobility H700 Wireless Headset
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
"Communications Error 608"
If you put the Toshiba Pocket PC e740 in your USB Cradle you may receive a "Communication Error 608". This is not a serious error, it is just a false setting in the ActiveSync Program. Please follow these steps below to correct this problem: "Tap" on start and choose the ActiveSync program Then "tap" on "Tools" and choose "Options" in the ActiveSync Program Check under "Enable synchronization when cradled using" to see if the setting is on "USB" If it is set on "Bluetooth", please change it to "USB". Now you can close the application window Important: Please remove the Pocket PC from the cradle and then return it to the cradle. This activates the new setting Important to note: This above described issue occurs if you "tap" accidently on the Bluetooth Icon in the Program Group or activate Bluetooth of any other reason, the ActiveSync Option will be set to "Bluetooth" instead of "USB". This setting will cause the "error 608" if you put in the Pocket PC e740 in the Cradle and start to synchronize over USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
Computers & Internet Logo
14 people viewed this question
Top Option Computers & Internet Experts
D. E. Hev
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Option Computer and Internet Expert? Answer questions, earn points and help others
