I have a Mitsubishi WD-Y57 it about 3 - 4 years old and I have never had any trouble with the unit until today. I turned the tv on and the sound came on but no picture, about a minute later the tv turned off and the green timer light on the front began to blink. I went through the manual and tried the reset button, but the same thing keeps happening, is it time for a new bulb or do I need a servidce tech to come take a look?
  • 556 Answers
If the green light continues to blink with out stopping this is not a lamp get a tech, it is a start up issue
Posted on Aug 17, 2009
SOURCE:
Mitsubishi WD 65737 black screen
Sounds like the back light has gone mate. Unfortunately this usually makes the tv obsolete
Dec 22, 2017 | Mitsubishi WD-73827 73" HDTV DLP TV
My mitsubishi tv is almost 3 years old and it has no picture but it has sound
Video board malfunctioning....Get a honest TV tech. Only three years old? It is worth repairing, will deliver several more years of excellent service. A quality television.
Mar 31, 2013 | Mitsubishi WD-62526 Projection TV
There is a deep hum that started coming from my 20 year old huge Mitsubishi floor model TV. Any ideas? I know, buy a new one, but I love this old hunk of a TV. Thanks !!
sculin,
Certainly a new one would solve the problem but from what you have said it would seem that yours should be reaparable. The only question would be whether it would be worth fixing if it costs alot to fix. Putting a large amount of money in a twenty year old set is usually asking for trouble. You said that the unit has a loud hum. Sounds like a low voltage power supply problem. I have a tip at
http://www.fixya.com/support/r6396176-projection_tv_troubleshooting
which will walk you through the troubleshooting process and should help solve your problem with the least amount of money.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 05, 2011 | Mitsubishi WD-82838 DLP TV
No sound great picture
Are you connected to a Cable box? then make sure cable box is not on MUTE and audio cables are attached.
From MENU check to see that speakers are not disabled on your TV.
Good Luck
N Sabre
Nov 07, 2009 | Mitsubishi WD-57734 57" HDTV
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi tv model wd-62531 less than 2 years old
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Dec 10, 2008 | Mitsubishi WD-62531 Projection Television
No video in any of the TV inputs
first try resetting and rebooting. reset = menu, 2470, enter.
reset is press reset button and wait for green lite to stop blinking.
if that takes care of it great. if not it sounds like a signal board or dm problem and will need repair. check out www.tv-techs.com
Sep 06, 2008 | Mitsubishi WD62628 62" Projection HDTV
Mitsubishi model# wd-62327
You will need to do a self diagnosis test first.
Dec 03, 2007 | Mitsubishi WD62327 TV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Ekse
