Question about HP OfficeJet 6110 All-In-One InkJet Printer
Everytime I try to print , all i get is a a blank page
All I getting is a blank page everytime I try to print something. It doesn't matter what program I am using. I turned the computer and printer off. I delete the printer connection and add it again. I don't know what else to do.
  • 3,153 Answers
If you are using it on a MAC there are known issues.
If however it is a pc then maybe you should check your ink levels using the software that you installed with the printer.
Have you recently replaced the ink cartridges and if so did you use original HP cartridges ?
If you didn't use original cartridges then there is quite a good chance that they may be faulty and should be returned to where you purchased them for replacement.
If you did use original cartridges did you remove the tape on it before installing ?
Check by doing the cartridge replacement steps and take out any cartridge you may have replaced recently and check that the pull off tape tags are removed.
Posted on Aug 19, 2009
6ya staff
SOURCE:
I am getting a blank page in between each copy everytime i print ????
I'm assuming your printing from a computer. try making your header and footer smaller. look at your print preview and adjust your text font if it runs into the next page. You can also select to just print a single page instead of ALL to see if everything fits on the page.
Sep 13, 2017 | In Office Equipment & Supplies
Everytime that I print a page it seems to print a blank one behind it. what can I do to fix this?
In the 'Printer Properties' try ticking (or unticking) the 'Fit to page' box. (or something like it).
Oct 28, 2013 | Epson DFX-9000 Matrix Printer
Does not print, just runs blank paper through. I have uninstalled and reinstalled several times and it doesn't help. It will run about 75 sheets through the printer and then it quits. Everytime I ask it to...
I take it you have plenty of toner.
Can you use the lcd menu on the printer to generate a test page? That will give you some idea of whether the issue lies with the device or the software that you are using.
Other possibilities:
You are trying to print something that is not printable,
or you have the wrong print driver,
or an old one.
This printer can do Postscript, but I think if you need to try different printer drivers, a PCL may do better.
Mar 06, 2010 | HP LaserJet 4 plus Printer
I have an HP C7280 AIO printer. Everytime I print, it always form feeds a blank page bewteen each printed page (print page 1, form feed a blank page, print page 2, form feed a blank page, and so on).
Generally, there are printer set up programs that will let you chose to put a blank sheet or to not do that. If you have a disk or manual, look for the set up utility and go thru the tabs to find paper handling or something similar to that. There should be a check box you can clear to stop the blank page.
I hope that this information was helpful. Have a great day.
Brian
Jan 24, 2010 | HP Photosmart C7280 Printer
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
PRINTER ONLY PRINTS CODES, NO IMAGES
you need to re-install the driver http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X2350
May 20, 2008 | Lexmark X2350 All-In-One InkJet Printer
Dell printer not printing!!
Ok, did you first make sure that the cartridges were fully inserted and not empty?
Feb 27, 2008 | Dell 922 All-In-One InkJet Printer
Fmc240 printer
i would check the toner cartridge first
Feb 20, 2008 | Office Equipment & Supplies
PRINTING BLANK SHEETS
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
105 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
