Question about LG Televison & Video
LG firestick TV with magnaxox DVR connected via HDMI. Worked fine 1st day, next morning msg remote was being reprogrammed, now HDMI wont work, use composite and sound no picture.
SOURCE:
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
  • 17 Answers
SOURCE: HDMI out to Olevia 527 TV = Blue Screen
Hi beelzyboob.. try checking these.. since you are using the RCA (composite cables) and I assume you have them on the "DVD in" at the back, go to setup, go to input assignment and go to hdmi input. here, make sure dvd is set to" ----". Next, hit return and go down to component input and also check if dvd is set to "-----". With these settings, you should get video. This is because you are not using either an HDMI or component cable. hope this helps.. ^_^
Posted on Nov 28, 2008
  • 49 Answers
SOURCE: Is there a super video to hdmi or composite video adaptor?
Hi cogitoneurop Yes is the simple answer, but depending on which way you need it to go, try this link http://cgi.ebay.co.uk/COMPOSITE-S-VIDEO-SVIDEO-AUDIO-TO-HDMI-CONVERTER_W0QQitemZ250487856744QQcmdZViewItemQQptZUK_ConsumerElectronics_VideoSwitches_SM?hash=item3a523d5e68#ht_3971wt_1054 hope it helps!
Posted on Dec 07, 2009
addmeps3
  • 61 Answers
SOURCE: PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Posted on Jun 28, 2010
  • 8457 Answers
SOURCE: My toshiba sdk990ku dvd player stopping playing
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Posted on Nov 18, 2010
Can i use a firestick with my sony wega kdf-e42a10
Fire TV Stick connections....
1 Connect USB cable into fireTV stick, and plug in power adapter. ...
2 Amazon fireTV stick and power adapter. ...
Connect fireTV stick to HDMI port via HDMI extender.
3 Amazon fireTV stick connected via HDMI EXTENDER CABLE TO Monitor HDMI port. ...
4 Turn on TV and select HDMI port
Feb 04, 2018 | Sony Televison & Video
Why wont my surround work with new Dish network dvr.
When the DISH Network installed hooked up their DVR, did they connect it via HDMI? If so, then it could be a bad HDMI connection. I would bet they simply bypassed your receiver and went straight to the TV, which is why no audio comes out of your receiver. You can test this by turning on your DVR and TV. If you see picture with your receiver OFF, then they bypassed your receiver. You'll need to hook up and HDMI cable from the DVR into the receiver and then out of the receiver to the TV.
Feb 21, 2016 | Denon AVR2112CI
Issues with LG 26LE5300 26 in HDTV LCD TV Both audio & video flicker off & on when connected to PC via an HDMI cable. No problem when in TV or AV (DVD) modes. PS. worked fine on Day 1, did not...
Reduce the resolution of the PC to 1024 x 768. This can be done by right clicking on the desktop ( not any icon ) click properties / click settings / slide the screen resolution pointer to 1024 by 768 / slick apply / Computer will ask if you want to save this setting /Click yes and then try connecting the TV to the HDMI port. Should work
Mar 11, 2011 | LG 26LE5300 26 in. LCD HDTV
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Feb 14, 2010 | Televison & Video
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Intermittently Working Correctly with DirecTv
Update your Harmony remote control software on your PC to the latest. Go into the TV device settings. The software should recognize if there is an update to your TV's IR commands. Try the same things with the DVR.
It's also possible the TV and/or DVR are locking up due to IR commands that are being sent too quickly. The remote has a setting for the delay between commands sent to the same device as well as the delay between commands sent to different devices. Try adjusting these settings:
  1. In the Harmony remote software on your PC, click the "Devices" tab.
  2. For the "TV" device, click the "Settings" button.
  3. Click the dot next to "Adjust the delays" and click Next.
  4. Adjust the "Inter-key" and "Inter-device" delays to something higher and click Next.
  5. Follow the steps to save the changes.
  6. Repeat steps 2-5 for your DVR device as well.
-=Zzed=-
Feb 19, 2008 | Logitech Harmony 880 LCD Remote Control
LG 42LB5DF Horizontal lines when first turning on
I have the same problem on my 42 inch LG 1080p and I read in the manual this could be due to interference. I have messed around with my other electronics but couldnt find the problem. I do live in a apartment so I dont know if maybe another persons electronics are causeing it or not. I will be contacting LG regarding this issue although it wont get me anywhere im sure, but I will post again If I should find a soulution.
Sep 29, 2007 | Televison & Video
Televison & Video Logo
29 people viewed this question
Ekse
