Question about LG Televison & Video
Is there a replacement "green" wiring harness available for the LG PA75U projector?
The LG PA75U is an awesome projector, but the wiring harness to the green circuit has a tendency to burn out (around pin 6) creating a purple screen image. It is very easy to see the burned pin when removing the cover on the green circuit versus the identical circuits for red or blue. Is it possible to get a replacement cable or to repair the molex connector pin? The white portion that clips on is the side that burns. The black connector block that is soldered to the circuit board does not seem to be affected.
SOURCE:
MNfisherman
  • 11896 Answers
SOURCE: 1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Posted on Jan 17, 2009
SOURCE: Tail light circuit burned out from trailer harness
IM LOOKING FOR SERVICE MANUAL TOO. HOPEFULLY DOWNLOADABLE ONE.
ANY HELP (KASANDEN@JUNO.COM)
Posted on Jul 19, 2009
  • 49 Answers
SOURCE: Avanti EWC-12 circuit board replacement (correction)
the green an yellow wire is a ground. Look for an area on the board with a ground symbol earth.gif. Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
Posted on Jan 16, 2010
SOURCE: Wires came loose of control unit from circuit
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Posted on Apr 22, 2010
maybe we can help each other out with the questioni have my white black and red still connected but the purple blue yellow green and brown cables are un soldered if u look at the transmitter with the buttons on the bottom and the screen at the top the wires should be on your right there should be nine spots strating from the bottom to upward skip 1 next one should be white then skip one next should be red then next one is black and then thats all i have hope we can help each other
Posted on Aug 20, 2010
How can i fix this white dots problem in my projector?
It would be a lot simpler and probably cheeper to replace the projector.
Dec 06, 2014 | LG Hs200 Projector
The projector is displaying a green color
Could be the color wheel or over-heating. Make sure the vents are all clear.
Mar 20, 2014 | LG DS420 DLP Projector
How do you replace the noise filter
you should see 4 or 6 wires connect wires having the same color 2 for neutral 2 for live voltage and 2 for ground having green and yellow color
Feb 10, 2014 | LG WM-2277HW Front Load Washer
Es lexus 300 p 1705...What is this?
DTC P1705 - NC2 (Direct Clutch Speed Sensor) Revolution Sensor Circuit malfunction or Direct Clutch Speed Sensor Output is 300 RPM or less with Vehicle at 20 MPH or more & with Park/Neutral Position Switch Off
Most probably you have an electrical fault causing the problem and attached is a diagnostic procedure. It could be 2 separate problems and after rectifying the P1705 only would you know it is single or 2. Repair manual shows right on top of transmission, black sensor with single bolt, 2 wire plug. P/N 89413-08020 list price $113.80
NOTE: DTC P1705 is set when PCM receives 2 gear position signals at the same time.
1. Turn ignition on. If any A/T gear position indicator lights remain illuminated when gear selector is moved from that gear, go to next step. If all A/T gear position indicator lights turn off when gear selector is moved from that gear, system is okay at this time.
2. Disconnect A/T gear position switch connector. If all A/T gear position switch indicators go out, replace A/T gear position switch. If all A/T gear position switch indicators do not go out, go to next step.
3. Reconnect A/T gear position switch connector. Shift through all gear positions except Reverse. Using a DVOM, measure voltage between 16-pin PCM harness connector "D", terminal No. 6 (Green/Red wire on 2.3CL or White wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires).
If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Red or White wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Red or White wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
4. Shift through all gear positions except Neutral and Park. Measure voltage between 16-pin PCM harness connector "D", terminal No. 13 (Blue/White wire on Accord or Light Green wire on 2.3CL and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Blue/White or Light Green wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Blue/White or Light Green wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
5. Shift through all gear positions except "D4". Measure voltage between 16-pin PCM harness connector "D", terminal No. 9 (Light Green/Black wire on 2.3CL or Yellow wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Light Green/Black or Yellow wire between 16-pin PCM harness connector "D" and A/T gear position switch. Repair as necessary. If Light Green/Black or Yellow wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
6. Shift through all gear positions except "D3". Measure voltage between 16-pin PCM harness connector "D", terminal No. 8 (Green/Blue wire on 2.3CL or Pink wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Blue or Pink wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Blue or Pink wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
7. Shift through all gear positions except "2". Measure voltage between 16-pin PCM harness connector "D", terminal No. 14 (Green/Yellow wire on 2.3CL or Blue wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Yellow or Blue wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Yellow or Blue wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
8. Shift through all gear positions except "1". Measure voltage between 16-pin PCM harness connector "D", terminal No. 15 (Light Green/White wire on 2.3CL or Brown wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, check for loose PCM harness connectors. Replace PCM with a known- good unit if necessary. If battery voltage is not present, check for a short in Light Green/White or Brown wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Light Green/White or Brown wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
Hope helps.
May 24, 2011 | Lexus ES 300 Cars & Trucks
Lg Dryer power connection -one of the wires is burnt. Need to replace it. How do I remove the top of the dryer ? Are the wires easy to find and replace ?
LG recommends replacing the entire wire harness to properly repair this unit. You will need to order the wire harness first from LG before making repairs.
Good Luck
Sep 24, 2010 | LG DLE5977 Electric Dryer
GREEN GLOW on NEC VT 770 projector
That will be a worn or damaged green LCD unit. If still available, extremely expensive.
Jun 22, 2017 | NEC VT770 Multimedia Projector
Abnormal picture
if it's an xr-32x (as it shows on this pic), it's a dlp projector, not an lcd. therefore no green filter. it has only a colorwheel and a dmd chip to affect the color. if it's not an xr-32x, and it's an lcd projector, replace the green filter. sharp sells the parts for the optical engine. but if it was your service tech that did it, have them replace it.
Jul 28, 2009 | Sharp XR-32X Projector
Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Jan 31, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Spares not available
FOr most service centers, the only available parts are the modules themselves. There are very few of us left that actually perform component level repairs. In the case of this type of unit, there are no component level parts available as the only "parts" supplied by LG are modules. Dep[ending upon the servicer's experience and the nature of the problem, it is possible that the module could be repaired. This would not be an "authorized" repair, but it is possible. What is the nature of the problem that warrants the requirement of the motherboard?
Dan
Apr 05, 2008 | LG LP XG2 Multimedia Projector
LG RU-44SZ63D
Hi there
This could possibly be your Ballast ( lamp's powersupply ) that is faulty.
It will either need repair or replacement.
Mar 31, 2008 | LG DLP Projector 1400Lum RD-JT30...
Televison & Video Logo
RONALD CARTER JR
