Question about Mitsubishi WD62327 TV
Mitsubishi model# wd-62327
We bought this tv two years ago, its been great, no issues untill today. When we go to turn the tv on, you can hear it turn on and warm up, then it turns off and the light near the power button that is normally green is red in color. whats going on?
  • Anonymous Jun 06, 2008
    my lamp light is red?
    Genius:
  • 1,153 Answers
You will need to do a self diagnosis test first.
Posted on Dec 03, 2007
SOURCE:
My tv was caught in a flood in the basement. IT is moded number WD 62327. For insurance purposes, can you please tell me when that model was last made and if I were to replace it today, what would the...
12 Jul 2006 ... Prices from $2145 ' Pros and Cons, Videos, Amazon Reviews, and Support. Read the full unbiased report on the Mitsubishi WD-62327.
www.productwiki.com/mitsubishi-wd-62327/ - United States - Cached
Hope that helps.
Feb 16, 2011 | Mitsubishi WD62327 TV
you have identified the problem good,
but you could specify the problem a bit accurately
:the possibilities of your problem might be because of.
1.fault in the circuit
or
2.problem in the display of your tv.
Dec 07, 2007 | Mitsubishi WD62327 TV
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Tv turns on for about 5 seconds then turns off then the lamp light flashes "green" what does this mean, i know the red steady light means replace lamp
There was a failure during startup meaning this could be a power supply issue, Bad capacitors in the powersupply can do this so I would have the Tv checked out.
please do leave positive feedback for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 06, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Where is the Lamp located in the Mitsubishi 2004 model the number is WD-62327
Turn unit around facing you, either on right rear side or left rear side, generally looks as though it is a vent cover with one to three screws holding cover in place. UNPLUG TV BEFORE YOU WORK ON IT AS ELECTRICITY CAN KILL YOU.
Oct 09, 2009 | Mitsubishi WD-62327 62" Rear Projection...
TV problem - Mitsubishi wd-62327 62
If the lamp is bad, you will hear a buzz noise as it tries to fire up the lamp. If you let it try enough it will spit out the error message. You can pop the speaker grille off and gain access to the lamp door. Use a philips screwdriver to get in. The lamp will be shattered or damaged looking if bad. If you have a good lamp, you may have 2 bad capacitors on the power board (3300uf). They will be bulged on the top and not flat. It is difficult to disassemble this tv.
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mirror
There is black insulating foam that surrounds the projector and it may be displaced to one side.This leaves about an 1 inch opening around the projector lens and that could be the source of the problem,dust being blown into the compartment with the mirrors.
Cleaned the mirrors really well and used double stick tape to reattach the foam to the plastic frame and this will closed off the opening that maybe letting the dust into the mirrored area of the TV.
Nov 12, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi 6043A Loss of color
Sounds like many different problems maybe related thou. You say 6043a but you are under WD-62327. So this info is for that.1. Suspect the Light Engine part # 939P977020 also you could need.. Suspect the Signal PCB part # 930B923002 if no video keeps up
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
