Every time I switch on my Goldman's tv i have to retune it how do i fix this
    New Friend:
  • 88 Answers
Is the TV on a switched power outlet? If the tv loses power it will lose memory
Posted on Jul 12, 2019
SOURCE:
Factory settings on Luxor tv
You should after factory settings ,when you tune the correct channel you must press store ,and if your doing it manual you must press store after each channel is found. That's should do the trick.
Sep 21, 2017 | Luxor Televison & Video
The tv is fine without the freeview box have tried new scart lead also new tv ariel leadand retunned several times
Are you getting any reception at all? Could it be that the antenna is not receiving the signals??
Jun 11, 2014 | Cameras
Mitsubishi cold 3.0 v6 workshop manuals
If your philips tv keeps losing it's stations when you switch it off, this my be a solution -----my 42" tv would need to be retuned every time I wanted to watch it this fault just started over night it was all working fine then sat down to watch tv and had to retune tv from scratch I could then watch telly all night fine change channels no probs all great switch it off next day retune and so it went on if you have this problem switch telly on then hold in menu button on tv until screen goes black (this reboots software) then retune tv as normal it will ask if you want a full retune (yes) when this is complete digital and analogue your tv should now remember channels when switched off and work as it used to ----( Hope this helps you if you have had this problem it worked for me ). Good Luck
May 29, 2014 | Televison & Video
Teac tv auto switches
need to get into its main menu and retune it maybe..or shut it off and restart it..
Jan 08, 2014 | Teac Audio Players & Recorders
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
No digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Jun 03, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
L11 Blurring
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Jul 15, 2008 | Nikon Coolpix L11 Digital Camera
Tuning problem
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 02, 2007 | Acer AT3705-MGW 37 in. LCD Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Ekse
