Question about Kenmore Washing Machines
Hello. I have a Kenmore model 110.28002012. it's spinning, but when it drains it drains poor. After all the cycles finish I have to run a second drain and spring cycle. I looked at the bottom of my washer and checked all drain hoses and didn't see any clogs. But what I did see was grease or gunk around the small pulley and on cover for it. Any ideas what causing all of this. Thanks
    Top Expert:
  • Kenmore Master
  • 29,167 Answers
SOURCE:
SOURCE: LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Posted on Dec 19, 2007
SOURCE: kenmore he2 front load washer
Open the panel with 1/4 in socket. Turn white plastic cap filter counter clockwise. remove debris. replace. Run rinse and spin cycle. reopen cap and check for any new debris. replace filter cap and put cover back on. put $65 in bank. Send note to Eddie Lampert and tell him that Sears sucks and he'll never save it as long as they keep screwing their customers by not telling them about a simple fix like like this to an obviously common problem.
Posted on Jan 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore 44072 Front Load Washer Drain Hose Cleaning
Try this link for step-by-step instructions. More than likely you will have to clean the drain pump as well.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are having trouble draining the water from the wash tub, and cannot get it to drain with a shop vac, you can drain it directly from the tub. If you don't own a shop vac, you may have to bail. If your drain pump does not have a clean out trap, remove the inlet and outlet hoses to access the inside of the drain pump. Inspect the pump impeller for obstructions and/or damage. If the water will not drain when you try to pull a vacuum on the drain line, you may have to disconnect the drain hose from the bottom of the wash tub. In some front loaders, there is a ball valve in the drain hose from the bottom of the wash tub to the drain pump. This ball can act as a collection pint from lint and debris. You will need to remove the hoses from the bottom of the wash tub to clean this area. I would recommend doing this as a LAST resort. Often, it can be difficult to reconnect this hose to the tub and get it to seal correctly. I hope this helps you. Please post back if you need further assistance.
Posted on May 28, 2008
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore stylemaster 902202 will not spin, agitate or drain tub spins freely
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 07, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Dec 28, 2010 | Kenmore Washing Machines
The washer wont drain and finish a cycle
Is the wash tub banging aroun in Spin Cycle and failing with a unbalance code of dC or uC?
What is the model number?
May 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Washing Machines Logo
50 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
