Should each plug hooking to the water valve have 120V with the timer on? Thanks
  • VickiDevon Smith
    VickiDevon Smith Jul 11, 2019
    That is one wire of each plug when water temp is set to warm.? I have 120V on each plug but not both wires of eac plug.
    Habit-Forming:
    New Friend:
  • 19 Answers
On warm setting yes
Posted on Jul 12, 2019
4 Suggested Answers
SOURCE:
milten1
  • 1304 Answers
SOURCE: no water flow to dishwasher
check to ensure you have proper volatage at the connection box behind the toe kick
the you will need to open the door to check the door switch for both voltage and continuity
Posted on Oct 21, 2009
  • 401 Answers
SOURCE: I have a Maytag dishwasher and the power is not
check you float,is it stuck up it should lift and drop freely. if thats ok and the wires are fine your timer is probably bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Mar 01, 2010
  • 5353 Answers
SOURCE: Intermatic T103P Timer (120V) Wiring Guidance
Copy following link for T103 timer wiring options:
The clock motor is 120Volts, but clock motor can be changed from WH1570 to WG1573, and this action changes 120V T103 into 208-277V T104 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 28, 2012
Jun 08, 2012 | Intermatic Hardware & Accessories
Kenmore dishwasher water stopped coming in
Check the valve under your sink. If that's on go to the dishwasher. Remove the bottom panel. Locate the water inlet valve (usually on the left hand side. Pull the two wires from it and put your voltmeter on it. Start the dishwasher and watch the meter. If it shows 120v then the valve is bad. if you don't get 120v, the board or timer is bad.
May 28, 2012 | Dishwashers
I need to know how to install a cellanoid in my Whirlpool Duet washer Mod # GHW9150PW4 is there a place to get the instructions?
Are you meaning the Water Inlet Solenoid Valve??????
If yes .... you need to know if your W/P Duet GHW9150P Front Load Washer really has a bad Water Inlet Solenoid Valve for the Hot and Cold water. This valve is where the Hot and Cold water hoses connect to the rear of your washer on the upper top left side in the rear as you are facing the washer. In my opinion it is highly unlikely that your Water Inlet Solenoid Valve is bad....but it is possible. Sometimes the filter screen in the inlet(s) of the Hot & Cold water valve can be stopped up with dirt, sediments, etc. If you turn off the water faucets and remove the Hot & Cold water hoses from the washing machine... you will be able to see the screens...if they are stopped up you can remove them with a small screw driver and clean them and reinstall them.
Hook up your hoses and turn on your water supply Hot and Cold faucets.
Here is a quick test procedure that you can do to verify the operation of the Water Inlet Solenoid Valve.
Verify that your water hoses are hooked up and the water faucets (Hot & Cold) are turned on.
Unplug the washer's 120Volt AC power supply cord from the electrical plug on the wall.
(1) Remove the top cover...There will be three screws on rear area of the cover: Left - Middle -Right.
(2) Once the top cover is removed...you will be able to see the Water Inlet Solenoid Valve...just follow the Hot & Cold water hoses from the wall to your washer. Usually the water inlet solenoid has a blue plastic housing assembly with (2) separate push-on or pull-off quick disconnect electrical connectors. One connector pair provides 120volt AC to the Hot water solenoid and the other connector pair provides the 120volt AC to the Cold water solenoid.
(3) Remove the push on or pull off quick disconnect electrical connector to one of the water inlet solenoids..It does not matter which one at this point in time.
(4) You will need an electrical 120v AC Test Cord. You can make this from an old lamp AC power cord or and old 120v AC Extension Cord. You will need two alligator test jumpers or leads (Radio Shack has them). The end of the test cord that plugs into wall is not to be modified. The other end of the test cord will have to be modified in order to conduct this testing. Strip back the insulation to reveal the two leads that will carry the 120v AC power. You should have one black lead (120v AC HOT) and one white lead (120v AC Neutral). Connect (1) alligator test lead to the black lead and insulate with electrical tape as necessary and connect (1) alligator test lead to the white lead and insulate with electrical tape as necessary You now have your 120v AC Test Cord ready. If you have a VOM test meter..you can connect the VOM meter to the two remaining alligator test leads. Have your VOM test meter set for AC Volts and on a scale that will measure 120v AC. Plug in your test cord to the 120V AC wall power. If everything is OK your meter should read approximately 120 Volts AC.
(5) Unplug your 120v AC Test Cord from the wall power.
(6) Connect your 120v AC Test Cord to your Water Inlet Solenoid Valve electrical terminals.
See Step (3).
(7) Plug your 120v AC Test Cord into wall power. If the water solenoid valve is good you should hear water surging thru the water solenoid valve. If you do not hear the water running thru the valve you can verify if the 120v AC is getting to the valve with your VOM. It should read 120v AC. If it does read 120Volts AC at the terminals of the valve and you do not hear the water then the valve is probably defective: Either stuck shut and won't open or the solenoid coil is open (Bad).
(8) Unplug your 120v AC Test Cord from wall power.
(9) Disconnect your (2) alligator test leads from the solenoid valve and re-install the electrical push on connectors that was disconnected in Step (3)
(10) You can now repeat this test on the other side of the Water Solenoid Valve (See Step 3).
(11) If both sides of the Water Solenoid Valve check out good...then your Water Inlet Solenoid Valve is good. If it does not check out then replace it.
(12) If your Water Inlet Solenoid Valve is good...then ....unfortunately, there is a good chance that the CCU module is bad. The CCU module is in effect a computer control unit and controls the overall operation of the washer. The CCU module will cost approximately $150.00
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Mar 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My intermatic model T104 was not activating. I bought a new one yesterday but sill not activating. Howcan I prove the unti when it has two white cable only. Please advise asap. Thanks
T104 is 240V timer with 240V clock motor.
-This timer will not work for 120V circuits.
-Test your two wires for 240V.
-If your load (lights, motor etc) is 120V then you need the T101 timer.
Confusion about cables
When you say 2 white cables, does each cable have a black and white line?
If you have two cables with black and white lines, then one comes from breaker box, and the other goes to load ( water heater, motor, lights etc.)
How to wire T104 for 240V
How to wire T101 for 120V
Sep 16, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
My plumber just installed a new water supply line for my dishwasher. Now the pump comes on but no water fills up in the machine. If I fill the bottom of the unit with water, it works just fine. Even though...
You don't know how many times I've heard and found the shutoff valve off or partly turned off. Water entering DW is from line pressure not pumping. Items to suspect (again) the water supply valve (would'nt be the first time a new valve is bad). The supply valve (3374621) at the Dw, the float safety switch (normally at front left side,)...remove lower rack, lift float housing up and down. You should hear a click both ways and the housing should be free. Is the Dw fill valve getting control signal from timer. Should be 120v for about 60 sec.
Ric
Mar 10, 2010 | Whirlpool 24 in. DU915QW Built-in...
No hot water comming out. Both water valves open. Doesn't matter which temp switch is on still comes out cold.
Remove the top & unplug the harness from the hot water side of the valve and with a meter check for 120v at plug. If you have voltage replace water inlet valve, if thers is not 120v at plug at valve replace control board
Dec 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
120v plugged into 220v outlet
Thata agood question maybe the motor and maybe a lot more like the water valve. the agitate and spin selonids and the timer. Cant say cause some of them may noy be out.
May 10, 2009 | Washing Machines
No water
no water getting to machine to start its cycle.
Jun 03, 2008 | Frigidaire 24 in. FDB126RB Built-in...
NOT TAKING IN WATER FOR WASH
Do the water valves click when you turn on the unit? Have someone test to see if the valves are getting 120vac to them when the water should be running in. Usually both valves don't fail at the same time unless the common wire to both is bad. Most problems of this nature end up in the wire connectors or timer control unit..The connectors at the valve or on the control itself. If you do have 120v at the valves then the valves themselves must be bad..only other way is if the line from the valves to the tank is plugged....highly unlikely. Let me know what you find and maybe I can help out more...
Feb 10, 2008 | Whirlpool AWT5108 Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
