Question about Dishwashers
How do you reset kitchen aid mod KUDE20FBSS0 - Dishwashers
    New Friend:
    Problem Solver:
  • 6 Answers
Not a repairman per-say but just try unplugging it for a half hour or a little longer if a half doesn't work. The electronic boards will hold some power for a little while, that's why I said do it for a while and maybe longer. Hey worth a shot to start with. Okay. Ben
Posted on Jul 12, 2019
3 Suggested Answers
SOURCE:
Macmarkus
  • 2605 Answers
SOURCE: Kitchen Aid dishwasher has no
Welcome to FixYa.
Based on your brief description, I'd suggest you likely have a faulty thermal fuse in the control board as you alluded to, but it is not resettable unfortunately.
It's pretty easy to replace or to check, I've attached a link below to change the fuse, but you can also use the link to access the thermal fuse to check it.
With the aid of an ohm meter, remove one wire and measure across the two contacts and it should show continuity, otherwise it's open and therefore no good.
The part is available at most brick & mortar part places or on-line at vendors such as "repairclinic.com" or searspartsdirect.com" to name a couple. Part number 8193762...looks like this image and retails for about $15-$20USD based on the model you provided.
This is the youtube link to help with the repair "how to".
http://www.youtube.com/watch?v=jdlVbTXm8SY&feature=player_embedded
Let me know how you make out or if you require any further assistance and I'll try to help in any manner I can. Good luck.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Apr 17, 2011
Macmarkus
  • 2605 Answers
SOURCE: no power kitchen aid dishwasher mod kuds01flss6
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a
kitchen aid dishwasher mod kuds01flss6 you appear to have a concern with no power to the control, correct ?
The one thing I'd suggest is the thermal fuse, typically the symptom you've described is associated with a bad thermal fuse. (part #
8193762)
Here's a helpful link below to a video from "repairclinic.com" to assist in changing (or simply checking it as shown in the second link) the fuse kit...it generalizes on most Whirlpool built dishwasher's such as yours, but if slightly different it is essentially the same.
http://www.youtube.com/user/RepairClinic#p/search/0/jdlVbTXm8SY
http://www.repairclinic.com/PartDetail/Thermal-Fuse/675813/679723
I'll watch for your reply and try and help going forward. Hopefully this will provide you with the solution you seek, but please keep me posted if not.
...If so, please take a moment to rate the assistance provided for you here today. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Oct 12, 2011
How do I replace oven temperature fuse on a Kitchenaid Superba gas oven Mod.#KGST307HBS6?
have looked at the schematics can't find a fuse anywhere
see all parts here...
Kitchen aid made by whirlpool.. http://www.appliancepartspros.com/parts-for-whirlpool-kgst307hbs6.html
bad temp sensor maybe?
Feb 07, 2018 | KitchenAid Ovens
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
No power kitchen aid dishwasher mod kuds01flss6 what do I check first after checking the door switch?
8193762)
Regards,
Macmarkus :)
Oct 12, 2011 | KitchenAid Dishwashers
Kitchen aid dishwasher with blinking lights. Manual says to call service tech.
and so you did / im a service tec . need more info th help . like mod and ( kitchen -aid ) . try looking in the front toe panel for a tec sheet this will tell you about the blinking lights and what the mean . get back with me if you need more help //mm fed back pls .
Dec 17, 2009 | Refrigerators
Hi! I'm having a problem with my dishwasher its a Kitchen Aid Mod # KUDK03CTSS3 It's is just rinsing the dishes then stops completely and the start/resume button flashes!
have you found a solution? i have the same model and it won't take the detergent and only rinses the dishes. please let me know! thanks.
Sep 26, 2009 | KitchenAid Dishwashers
KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Feb 26, 2009 | KitchenAid Dishwashers
Stinky Ice
You could try using ice aid, http://www.partadvantage.com/store/showpart/10127281. However there is nothing on a fridge that causes an odor only things that are put into the fridge i.e. food, water quality.
Nov 07, 2007 | Refrigerators
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
