Question about Kenmore Washing Machines
How to manually open washing machine door Kenmore HE2t?
  • Kenmore Master
  • 5,767 Answers
I suspect there is no easy way to open the door manually and it is likely to be necessary to remove the cabinet top and manipulate the door interlock manually if possible or remove it.
An engineer with a laptop might be able to command the interlock of a modern computerised machine...
Posted on Jul 12, 2019
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: KENMORE HE2T WASHING MACHINE
"F25" is a tachometer error. If the control unit is unable to detect the proper motor speed, the machine will shut down. You can attempt to unplug the washer for at least 30 minutes to reset the computer. Sometimes this is all that is required to correct momentary glitches. If the error reappears, the manufacturer recommends the following:
1. Check the wiring harness between the Central Control Unit, Motor Control Unit and Drive Motor to ensure they are all connected properly and not broken or loose. This would be connections L2 and N1 at the MCU and connector MS2 pins 1 and 2 at the CCU. (There is a wiring diagram inside the washer behind the lower kick panel).
2. Verify the Drive Motor is turning and the motor windings are good. Resistance checks at the drive motor connector acros Pins 1 to 2, 2 to 3, and 1 to 3 should all read about 6 ohms.
I hope this helps you.
PS I believe the tachometer is a physically attached to the drive motor.
Posted on Nov 12, 2008
  • 57 Answers
SOURCE: how do i replace the pump in a kenmore he2t front ...
The outlet pump can be easily identified by reverse tracing the outlet pipe most of the unit will have at the back of the unit so remove the back side cover you can see the pump two clips will be present one from the drum and another is connected to the outlet pipe just remove the clips then two screws will be presented kindly remove those to unfix the pump from the machine then you can easily replace the pump
Posted on May 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: No Power and door is locked w/load inside
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE2T won't turn on and door is locked
Macmarkus
  • 2605 Answers
SOURCE: I have a kenmore he2t washing machine. The door
Hello Carl,
Welcome to FixYa.
In the case where the door won't open it is typically due to the pressure switch telling the control water is still present in the basket/tub...even if you can't see it, hence the control will not allow the door to unlock.
The first step then is to insure water is removed from the unit via the filter in the pump. If you are near a floor drain this won't be too bad, if not...a wet-dry shop vac and towels close by is recommended.
Remove the access panel at the bottom below the basket door and there you should see something like what is show here...the pump and removable filter. ( Being yours is the HE2 model it will be slightly different but the procedure is the same )
**Turn the breaker off to the machine or unplug it from the wall...safety first*
Should the door still refuse to unlock there is a manual unlock cord attached to the lock/door switch assembly.
From the opening of the bottom panel you'll need to twist yourself around to look up at the latch assembly or feel around for the latch, locate the "loop" and pulling it should open the door, this image shows what to look for...from the perspective I mentioned, looking up from the bottom.
That should do it, keep me posted. Thank you for choosing FixYa today, please take a moment to rate my info and leave a testimony.
Let me know how you make out or if anything is not clear and I'll help in whatever manner I can going forward. Good luck.
Regards,
Macmarkus :)
Posted on Mar 08, 2011
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore he2t
fluff may have blocked the filter or jammed the drain pump. you need to check these
May 07, 2014 | Washing Machines
Won't run, can't unlock th door, and it's holding my clothes hostage.
Hi Jay , seems like there is something stuck in the drain pump . Clear the pump ( use a wet vac and open pump cap slowly to catch all that water ) . If that does work make sure you getting power from the wall. that should free those poor hostages !
GOOD LUCK
APPLIANCES R'EN
Dec 06, 2013 | Kenmore HE2t 3.7 cu. ft. Front Load...
My Kenmore HE2t washer locked it will not open after unplugging and pressing button to cancel after error message how do I get door opened
Try turning the machine on and manual advancing through a complete cycle. Then wait five minutes. Do this several times. If the problem persists, it would be best to get a qualified Technician to check the machine out.
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Kenmore HE2 Plus Front Load Washer
I have a he2t wash comes out smelling like mildew really tired of it please do not tell me to leave the door opened I do still smells
The trick is to clean the interior using regular detergent, baking soda, and hot water; run a complete cycle without any laundry in it. Wash the rubber boot where the door seals with same mixture at which point the interior should smell fresh and clean. Now is the time to leave the door open after use so that the remaining moisture can evaporate out to prevent mold growth. Hope this helps!
Sep 23, 2010 | Kenmore 44072 Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine will not turn on it shut off
Have you tried unplugging the unit and waiting for a minute and then plug it back in. The load might have been off balance and caused that condition. Once it has been reset you might be able top end the cycle.
Dec 07, 2017 | Kenmore HE2 Plus Front Load Washer
Every time I start my Kenmore HE2t washer there is
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Washing Machines Logo
41 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
